Do you use chassis skid plates for protection?
#16
I would say run it until you feel a drop in performance, either too much flex, or excessive wear. chassis will wear down, but if they aren't causing problems, then there is no problem. It comes down to personal preference though, everybody will have a different idea of when the chassis should be replaced.
#17
I use them all the time. I have machined some from work. That I made used them for 3 years never had one bent or break I think I posted a pic of how to make the perfect Dodd for the d8 and d8t a long time ago. the rear of my chassie still looks new lol. But I'm not too hard on my cars or at least I don't think I am.. If the front of the skid is machined down it will not catch and Mess you up.i will post a pic of mine over the weekend and you can see how I did it.
#18
So I haven't used a skid plate that sticks off the back of the chassis since I had problems with my rc8.2, about 6 months ago. Here's something you guys are not thinking of when it comes to chassis. Aluminum is a very malleable metal, which means it is able to be bent easily, especially with the additive of heat. So by continuously cycling our chassis with heat in them from the engine and the amount of flex that out 1/8th scale cars have, the chassis will be tweaked or become too flexible well before the chassis wears out at the back end.
Ran my rc8.2 for about a year using the skid plates, and at the end I kept breaking chassis supports, had funky inconsistent handling issues, and while being very well balance side to side, the car would jump and pitch at weird angles. Replaced the chassis and all was fixed.
#19
#20
#22
#23
However some tracks are very very abrasive and will wear your chassis away in a very short time indeed.
#26
When I had my MP9 tki3 I was talking to Elliot Boots about my car set up.
Upon looking at my car literally the first thing he said was get that thing off referring to the chassis wear plate.
I've never seen anyone using one at National level.
#27
I like how Agama incorporated a skid plate on there buggy design.
#28
I never had a plastic DE bend on me. They are good to gauge your setup. If you are going thru them fast then your suspense is too soft for that track. So use them to help you setup your buggy without premature wear of your chassis plate.
#29
I covered the bottom of my chassis with carbon fiber to stop my wear issues, Has worked brilliantly and not affected the handling within my skill level.
#30
I would think carbon fiber cover would change the handling characteristics, Cause I'm sure it prob takes away some chassis flex as well!
