tmaxx reciever help asap
hey got putting ny tmaxx bak together wat wires go were on the reciever, theres 3 wires 2 red and black wires and 1 gray and black wat slots do they go into, the slots say b 123 thank u guys
Time to call the Grammar police
Ok, well red is a positive wire, black is negative, and grey is the signal.
If you look on the receiver you should see little symbols that look like a + and a - over two of the receiver ports. Match the red wire to the + pin and the connector should connect just fine. It will be plugged into channel 2 on the receiver.
lol, sorry, im posting from my phone and its hard to type, ok now that i have it hooked up rite, the throttle is working fine, and the servo is turning, but its like something is binding up, its not turning the wheels, but when i disconnect the arm on the servo it turns fine, sumbody was saying the pivot balls, even when i have them alll the way loose, it doesnt make a diffrence, any ideas?
i was thinking that to, i took everything apart everything seemed to be ok
thanks guys for the help, im pretty sure i found the problem, i took apart the steering bell crank, and one of the rods the go threw and bolt to the frame are bent, im almost 100% sure this is it beacause, it was binding, what do you think?
