MY SERVO CATCHES on FiRE!!
#46
Cheap Spektrum will always glitch with Savox.
I mean, A Main has that disclaimer there for that specific reason...
All this said, I have had a couple 1267s and 1258s fail, but I keep using them because the warranty is so good.
#47
I see a couple of things that stand out to me.
1. As others have stated, that servo isn't sufficient for the load being placed on it. People tend to underestimate the torque and stress put on a servo when operating the brakes.
2. It's a Losi, which is notorious for eating throttle servos. There's a reason Losi updates the radio tray every 3 months. (not literally but they are on Rev3)
3. Seeing all of this, I'm also going to assume the EPA's aren't setup correctly. You'd be surprised at how many people don't have their's correct.
I've had cheaper servos and I've had the best ones money can buy, I've never had one fail. I attribute this to proper setup and checking my EPA's every time I go through my car. At no point should your servo bind. When at rest, in neutral position, there should be no force on them either.
#49
Spectrum dx2e it has steering reverse throttle reverse throttle trim and steering trim and steering dual rate
#52
So everyone is telling me the servo I used is cheap skate and is no good but no one is telling me what servo I should use?
#53
Then a good digital servo with respectable speed and torque. You dont need to spend loads of money.
This savox would be fine.http://www.amainhobbies.com/product_...o-High-Voltage
I prefer futaba servos over savax but they cost more $$
http://www.amainhobbies.com/product_...ium-Gear-Servo
Without end point adjustments you will blow through digital servos.
#55
I have run Savox for a long time with no issues. The only one I killed was totally my fault. I grabbed a 1258 by accident and put it on my truggy for a steering servo. That did not end well....
#57
First get a radio that has end point adjustments or you will keep blowing through servos. You cannot have the servo stalling and full throttle. It will fry the servo or strip gears in no time. Something like this would do just fine. http://www.amainhobbies.com/product_...304SB-Receiver
#59
ATTENTION! would anyone recommend using proteks line of servos? Iv heard good things about them. And there a reasonable price for me. I'm really want to buy one of these >>> http://www.amainhobbies.com/product_...=Product-Feeds
OR this>> http://www.amainhobbies.com/product_...o-High-Voltage
