RB's innovative Automatic Dampening System
#136
That's possible ! Then it's not a good way to register on the RB site for American customers. I wanted to say too, if RB has not the parts in stock actually, it is difficult for their distibutors to have them.
I will wait to order one kit for my RC8 when it will be produce and available.
They should do it for Tekno too...
Mr Moroni
It's a really good thing to see you here, we can now talk about technical solutions and about the ADS system.
Can you tell us if you have made a definitive version or if you are working on other slots designs ?
Bye !
#137
do they have one for truggy? specifically for a losi truggy. couldn't find any
#138
Why ads don't release yet for sworkz ? And why people in europe already have it, can you inform me where can I get ads for sworkz
#139
Get a break on all orders today and receive some nice discounts on orders over $100. ADS shock parts are of course included.
www.amainhobbies.com/4thsale
#140
RB damping system for Serpent Cobra - is that for the old Serpent 811 or the new Serpent 811 2.0?
#141
#142
Hi guys,
I've run these in my Sworkz Ebuggy twice now, and both times have been 1s per lap slower back to back than with the std shocks, using a variety of oils from 700cst to 1000st.
I am clearly not setting them right as I don't believe they are his bad, is there any way if knowing what range of setting to use based on std shock setting, eg if you run 450 in normal shocks, start at 700 for AZdS, etc?
Also, do they react badly to being paired with soft springs? Are they more sensitive to ride height (or shock mounting, eg depending on these depends on where in the sleeve it most uses)?
I am just trying to get a handle on them and get them closer to working well for me...currently feels like they are not liking my soft spring setup, and also like they go too hard too soon in the compression!?
#144
I have now used the RB ADS System for 2 days on my Mugen MBX7 on the track where we held The Dirt Nitro Challenge - Rio de Janeiro. I am using 1100 front / 900 rear with the stock springs. Still need to test other springs with the system. I was able to improve my fastest lap time by more than one second (part of it for sure is increased grip and knowing the track better), but I was as well more consistent. The chassis slaps only when I am missing the reception area of the jumps, but stays very controllable even in such circumstances. What oils / springs are you folks using on your MBX7?
#145
Hi guys,
#146
Not sure if you're familiar with the 2.0 shocks but I can't seem to find any proper documentation for these new shocks so I can imagine other people struggle with this as well...
Gaoske
#147
This might be the difference between the PRO 2.0 shocks and the defaults in the kits. The Pro has a different mounting form for the piston: The piston goes over a shaft in which a screw tightens the whole. The "old" kit-shocks have the conventional nut tightening over thread.
Gaoske
Gaoske
Anyways, I run on a high bite blue true track with cl big jumps so I need a lot of pack and the front shock didn't seem to be able to supply enough. I may need to try 20000cst oil in the front. The shocks did however work very well through a washboard section at the track....
#148
I have also tried them in my Sworkz e buggy and found they do not have enough pack in the front. I went up to losi 100wt in the front and still not enough, the chassis slaps hard from less than a 1 foot drop. Also, the hole in which the piston mounts to the shock shaft has a significantly larger diamiter than the shaft itself, this leads to alot of movement of the shaft causing leakage from the bottom seal.......
#149
Anyone tried these on the xb4? What oil weights are good to start with? Springs? Thoughts on trying with the progressive springs?
#150
hi all
i already got my ads for sworkz today, i was confuse when i must setup for the rebound, manual said i must set the rebound as minimum. can someone help me step by step setup for ads system cause when i want to setup my rebound the ads system went out from the shock body.
