CSI PRO CLICKER SERIES SHOCKS
#451
Is there any intention to do any shocks for the D812?
#452
mugen mbx7 shock
will the csi clicker shock made for the mbx7 interchange with the mbx6? will I need a different length shaft to make this work? thank you very much for the innovation of this shock technology!
#453
#454
Also, for the MBX7R, all you need to do is change out the Rear tower to the MBX7. They made the New MBX7R Rear shocks a little shorter, performance wise it does nothing.
#455
I wish I could honestly answer this or you, but the one chassis we have never invested in is XRAY, nothing personal, we just focused on other brands. I do know we have had customers bolt CSI shocks on the XRAY as well as Tekno.
#456
Your shocks shipped this morning Todd... We also emailed you the (option 2) assembly diagram which is the way we recommend to run the CSI shocks.
#459
#460
New Products released along with great New pricing on all CSI products.
CSI/Mugen 16mm Squared V-Port Piston Set (Blue) Part CRP-0027
CSI/Mugen 16mm Squared V-Port Piston Set (Red) Part CRP-0028
CSI XD 17mm Lightweight Aluminum Wheel Nuts (Blue) Part CRP-0024
CSI/Mugen EX Performance Shock O Ring Set Part CRP-0029
CSI Clicker Shock EX Performance Shock O Ring Set CRP-0030
CSI/Mugen Aluminum Shock Spring Cups (Blue) (4)
CSI/Kyosho Aluminum Shock Spring Cups (Blue) (4)
Find your closest CRP dealer www.team-crp.com
#463
I got the Associated Clickers. All you have to do is get the mounting hardare for whatever Clicker set you get. If Mugen version set get Mugen mounting hardware and screws, if Associated set get Associated mounting hardware. In your case like mine, get the Associated version Clickers, Associated upper shock tower mounts, bushing/inserts and screws. It comes as a set on amain or any other large retailer. Ebay would have it im sure too. The shock mounts are separate if i remember correctly. Then just take your Xray shock rod ends and thread them onto the shock shaft. This is the bitch part kinda cuz they are 3.5mm and the shaft is 4mm... just takes a little elbow grease and voila!! you have the best rc shocks on earth for your Xray.
#464
