CSI PRO CLICKER SERIES SHOCKS
#227
It doesn't matter if it's smooth or has the protrusion. Look closely at the picture in post #220. The extra material between the slot in the cup forms an air tunnel and allows the boot to breath.
#228
You want to have the boot on the shock, put the spring on the shock, put the spring cup on the bottom of the spring, compress the spring with the cup on the bottom, pinch the bottom of the boot, slide boot over shock end, slide the gap in the spring cup over the pinched part of the boot. Or instead of pinching slide a 2mm wrench between boot and shock end and slide the gap in spring cup over it...
Hope thats not too confusing
#229
#232
#235
Are those fully compressed numbers? Because on my 8.2 I set droop at ~102mm up front and ~120mm in the rear. Measured center to center.
Also, I have a small gripe about the shocks as I just received them. Do they seriously not have a bleeder hole of any sort? Any reasoning behind that?
#239
and ahh okay that sound better about being fully extended numbers.
#240
