INTECH RACING - BR-6 BUGGY!!! >
Old 08-20-2013 | 08:58 AM
  #1501
I had a similar issue. I increased the rear camber to -3 and that seemed to help. I used to run the purple springs but like the orange and pink combo better.
Originally Posted by thommi
While having a break in the state championship, I am now using the BR-6 to test and find a setup. I have been running the Intech purple springs with 550 front and 500 rear oils, 1.3 mm piston, diffs are 5-5-3. The car is very good as long it's in the air... lol
The biggest issue I have with it is from mid to end of corner. I got a very good turn-in but I loose rear traction at once and have a hard time to keep the car under control. I am using the car on a track built by Joey down here in Rio de Janeiro and we got very high grip on it. I am using the Procircuit Hot Dices Soft compounds. Rear upper links are long in lower hole on tower. Any ideas what I can do about?
masher81 is offline
Old 08-20-2013 | 10:45 AM
  #1502
Running the rear camber link long can actually make it break traction, it does add traction but it can break traction fast
gofast072 is offline
Old 08-20-2013 | 11:22 AM
  #1503
I had the issue as well with the rear camber link in the middle whole, so I don't think that this is motivating the break. It feels like the car has just too much front traction and is "throwing" the back around...
thommi is offline
Old 08-20-2013 | 01:22 PM
  #1504
Maybe experiment with sway bars. My cars are extremely locked down in the rear. But, I know some guys run the 2.4mm in rear and I run the 2.6 (stock). Just a thought. I do run the lowest hole on for the camber link on the tower.
Ben Burtle is offline
Old 08-20-2013 | 02:29 PM
  #1505
Ben, I have to get the swaybars.. as always (or most of the time) here in Brazil, this will take some time to get... I did run both middle and lower holes on the tower, the problem did continue. I have been running on a low traction track as well with the car, and there its much more balanced. The problem really comes up on a high grip track. The front just keeps all the grip and the backend gets thrown around... I am thinking about maybe running 7-5-5 to take some steering away. What springs are you using, Ben? I have tested all blue and all pink so far. Blue seems way to soft overall, but I might mix them, pink front, blue rear. or even more extrem, white front, pink rear.
thommi is offline
Old 08-20-2013 | 02:41 PM
  #1506
Try to increase the rear camber.
masher81 is offline
Old 08-20-2013 | 03:09 PM
  #1507
i think everyone is using the vp pro progressive springs, they are waaaay better. I run pink in front and red in rear, unless track is extremely loose then ill switch to orange rear.
Old 08-21-2013 | 06:43 AM
  #1508
big greg's Avatar
And maybe the cement in the shocks is a little to do with it. I'm at 350-300 and the front still feels heavy
big greg is offline
Old 08-21-2013 | 06:58 AM
  #1509
The VP Pro pink in front and orange in the rear are the ticket for me.
Greg B is offline
Old 08-21-2013 | 07:03 AM
  #1510
VPProUSA's Avatar
If you are after side bite, use 1 down for the anti-squat. That takes away forward bite but adds side bite so the rear feels more locked in. I am using that right now because the last track I raced on was whipping the rear around turns too fast. The 1' anti-squat rather then 3' solved it.
VPProUSA is offline
Old 08-21-2013 | 08:02 AM
  #1511
Thanks Gene, that's an easy one to adjust...
thommi is offline
Old 08-21-2013 | 08:16 AM
  #1512
Joey Powell's Avatar
You could also raise the rear inner camber link to add side bite.
Joey Powell is offline
Old 08-26-2013 | 04:16 PM
  #1513
i can say enough about the intech br6, this thing is so dialed, it drove like a slot car. I would have had the win but had a flameout in the pits on my last stop, my heavy fingers fault, tank was dry coming up the pit lane.
Old 08-28-2013 | 07:21 PM
  #1514
IRSR's Avatar
Default INTECH German driver- Micha gets 2nd place
Micha Widmaier finished the 1st run of the German Championship in Oberhausen in the junior final with his INTECH BR-6 and placed the 2nd. Congratulations!
IRSR is offline
Old 08-31-2013 | 12:19 PM
  #1515
I have heard that the plastic is bad on these buggies, is that true? I am driving the MBX6-r now and planning to change brand next season. How would you who have driven both compare the Intech and the mbx6?
flat7 is offline
