Team Associated RC8.2 Factory Team Kit is coming
#7367
move turnbuckles to front hole on bell crank or a stiffer sway bar up front stiffer springs heavier fluid all the opposites of trying to gain front traction i'd move the turnbuckle first as you can always put it back if it dont help well you can put all things back i said. only do 1 thing at a time till you find what works for him
#7368
no i meant forward
EFFECTS OF ACKERMANN ADJUSTMENT
STEERING ROD INNER MOUNTING
POSITION
CHARACTERISTICS
Forward holes (sharper angle)
• Smoothens out steering response
• Car reacts smoothly
• Better suited to smooth flowing tracks
Rearward holes (shallower angle)
• Quickens initial steering response
• Car reacts faster to steering input
• Better suited to small, tight tracks
POSITION
CHARACTERISTICS
#7371
Thanks guys.
#7374
i always thought it was bottom was less aggressive middle was medium and top was most aggressive
#7375
#7376
TUNING WITH ACKERMANN
The standard setting (kit setting) on most vehicles is so as to make the vehicle easy to drive. Making the Ackermann Link longer (in most cases, the link will be swept back instead of parallel with the front suspension arms) will take away Ackermann, but make the steering more aggressive entering a corner. Making the link shorter (in most cases, the link will be more parallel with the front suspension arm) will result in more Ackermann, or less aggressive, and make the steering smoother and more predictable.
On cars with steering bellcranks, you can add a .100″ shim (2.5mm) under the ball end. You will also need to use a longer ball end to accomodate the spacer. This will result in more Ackermann.
#7378
You guys have it backward watch Brandon's vid I put up back is less
#7380
But Brandon is correct I have tried it. Try it for yourself he is 100 percent correct.back is less aggressive front is most
