Best Diff Gear Grease >
Old 01-06-2011, 04:45 PM
  #16
i have test 3 grease at my Ring/Pinion, The Kyosho Ring Gear Grease ,Team Losi Great Grease, Mobil 1 Full Synthetic ,
The best is the Kyosho , far away !!!
the_winner is offline
Old 01-06-2011, 04:51 PM
  #17
mccutch12001's Avatar
I use the Team Losi "Great Grease'. I'm sure its some kind of regular chassis grease or something, just in a smaller tube and overpriced. Plan on using the Mobil 1 when I run out.
mccutch12001 is offline
Old 01-06-2011, 07:16 PM
  #18
jwm2's Avatar
Originally Posted by Teccmoney
Lol that's funny... We are actually talking about not actually filling diffs but lubing the outdrives, ring and pinion gears, cvds, and bearings... O yea and o rings...
Ahh ok, that explains it. I didn't see that and was thinking you folks were filling your diffs with this grease, haha. Yeah i use some black lithium grease i had laying around for my grease gun. Works as well as the stuff losi charges an arm and a leg for
jwm2 is offline
Old 01-06-2011, 09:07 PM
  #19
Frank L's Avatar
Trader Rating: 148 (100%+)
I like the mobile 1 red stuff too. I have used the hudy graphite stuff and it's good but it sure goes quickly.
Has anyone tried or heard about this new rb copper stuff?
http://www.amainhobbies.com/product_...er-Grease-35oz
Frank L is offline
Old 01-06-2011, 09:31 PM
  #20
What made you come to that conclusion??
Soapy is offline
Old 01-06-2011, 09:54 PM
  #21
oghobavo's Avatar
Am I the only that uses the little tube of white lithium grease from advanced auto parts? Been using it on ring and pinion gears forever, never had any issues
oghobavo is offline
Old 01-07-2011, 12:27 AM
  #22
shanty140's Avatar
Have anyone tried this Eureka grease? If so, how do you like it?
http://www.amainhobbies.com/product_...-Pro-Gear-Lube
shanty140 is offline
Old 01-07-2011, 01:09 AM
  #23
this grease has been used on Jack Hammers for a long time, it's the best lube in metal on metal app's, great stuff for outdrives and cv's
HBTRAV is offline
Old 01-07-2011, 01:34 AM
  #24
For the pinion and diff ring, I use this stuff
http://www.modelixracing.com/ultimat...ng&n=1&pagina=
Sticks like S**t to a wool blanket.
It takes a little bit of running in and the car isn't free running when first applied, but man it's good stuff and doesn't come off.
Flipfly is offline
Old 01-07-2011, 02:23 AM
  #25
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
I have tryed heaps of different brands
The eureka grease is pretty good
The best by far has been the kyosho hg grease. I use it on all the cv's ring and pinions and outdrives. I haven't had to replace a part since switching to it. Imbought a tub 2 years ago and it's still going.
http://www.amainhobbies.com/product_...G-Joint-Grease
TIX is offline
Old 01-07-2011, 08:19 AM
  #26
rpm1968's Avatar
Trader Rating: 18 (100%+)
I've been coating metal to metal gears in my Mugens since the 6 came out.
This newest Ceramic coating I am using is designed for lubricity & wear, it's used in the firearm industry.
For me the biggest advantage is its "dry" application.
If you end up getting dust/dirt in the diff. housing, it doesn't stick to a "wet" lube on the gears.
rpm1968 is offline
Old 01-07-2011, 09:11 AM
  #27
THE PHILLY JYNX's Avatar
RPM How long is the coating lasting on the mesh of the gears before it wears off? By your post i'm asuming you use no form of wet lubrataion on your gears at all?
THE PHILLY JYNX is offline
Old 01-07-2011, 09:21 AM
  #28
johnny t's Avatar
looks somewhat like cerakote. care to divulge any further RPM?
johnny t is offline
Old 01-07-2011, 12:09 PM
  #29
rpm1968's Avatar
Correct, no grease on the ring & pinion.
Inside the diffs., I've had it on 2 years, no wear.
Outside (ring & pinion, spur & clutch bell), gallons, no wear.
rpm1968 is offline
Old 01-07-2011, 12:16 PM
  #30
rpm1968's Avatar
It is a Cerakote product.
I have been using that brand for a while.
They seem to have the most diverse product range to encompass our needs.
Heat Insulation, Heat Dispersion and Lubricty.
rpm1968 is offline
