Toe Angle
#16
You are absolutely correct for a full size vehicle.
However, in scale, 99.999% of setup sheets (like Drakes) are stated on a per-side basis.
So when they say 2deg. front toe out; they mean 2 deg. per side.
That said...
Turn your radio on and center the servo as you wish.
Stand the vehicle vertical, on it's nose/front bumper; on a level, hard surface (setup board).
Use your camber gauge to measure the "camber" (which is now toe in this case). Toe out will read as negative camber.
That said...
