Losi Starter Box - Original
Quick Question - and not IM NOT BUYING THE OFNA STARTER BOX.
CAN SOMEONE TELL ME WHAT BELT YOU USE WHEN INSTALLING A 775 MOTOR IN THE ORIGIANL LOSI 8T STARTER BOX.
THANKS
THANKS
Token, this should be what you need. I hope this helps.
http://www.horizonhobby.com/Products...prodDetailTabs
i know tokens title says no truggy box but i would seriously look into one. i went thru at least 5 brand new losi 8ight boxes in one summer season. now with 2 truggy boxes starting my cars they have yet to faulter almost 2 years. those losi box days sucked
Mines Still ticking.
I used the losi 775 motor and the 550 motor as a dummy ,only wire the 775 get new pinons at amain and drill them out to 3/16 to fit motor shaft and then drill and tap on the side for 4-40 set screw use the same belt as before ,,,its tight in the box but it works ,use a 14.8 4c lipo and it will start a tractor ,I think the nitro motor has to slow down after it starts ,,LOL
When I ran losi's I had the first version and the second. Burned up th motors in the first and threw two belts in the second. I finally switched to the ofna and just love it.
