Veggo "revolutionary" plastic tire inserts
New AIRBAG inserts available.
AIRBAG is the revolutionary tyre insert developed and produced in Italy. Due to its unique and incredible features, AIRBAG is a must have for all serious racers.
Characteristics:
* PERFECTLY BALANCED: just drop'em on and see the difference
* ZERO CENTRIFUGATION: it means perfect contact of the tyre with the racing surface for improved traction and optimal steering response
* TOTAL CONTROL: less side roll and less tyre wear
* ULTRA RESISTANT: won't break as standard foams and don't collect dirt wihich can alter tyre responsiveness
* PERFECT MATCH: they fit perfectly on the rim due to exclusive internal pattern
* WATER RESISTANT: wash your tires without ani issue
* DURABLE: can be used many times with multiple set of tires because they have no degrade
AIRBAG inserts are available in 3 different compounds:
* RED: soft compound
* YELLOW: medium compound
* GREEN: hard compound
AIRBAG inserts are sold in set of 4 of same compound
Characteristics:
Looking funky.
Interesting no doubt.
Very nice. Any prices on them?
Looks like the sidewall will have no support where the hollow areas are
How much do they weigh?
Ah, there are tons of products in every industry with varying results
don't see how it could work when the tire balloons.
Sounds like they found a way to defy physics.
Not really - if the plastic insert supports the sidewall in a horizontal direction there won't be any material to expand vertically. I'm sure the tire will stretch a bit and balloon but it would be far less dramatic than with a open cell or closed cell foam.
Hmmm
I would think they are inflated to a point where it would stretch the tire compound to a point where it could allow a pretty stiff sidewall. Some of you were saying that it would be too weak on the sidewalls... remember that you do want a little sidewall "flex" so that it conforms to the angle of the surface your on.
I'm interested to see how these work.. should be interesting.
