Clutch Bearings >
Clutch Bearings
Like Tree14Likes
Clutch Bearings
Old 11-21-2023, 09:15 AM
  #46
token's Avatar
Ceramic bearings will not touch my 8th scale rides. A unnecessary expense.
petersen114 likes this.
token is offline
Old 11-22-2023, 08:15 AM
  #47
Goof's Avatar
Trader Rating: 81 (99%+)
I use them everywhere but the hubs but very expensive
Goof is offline
Old 01-11-2024, 07:04 PM
  #48
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Yall need to watch this. Your welcome 🤙
https://youtu.be/RmFrAf3a0aA?si=2zTymoRLmoGKstes
Tony Newland is offline
Old 01-11-2024, 08:21 PM
  #49
Trader Rating: 29 (100%+)
not even a drop of oil for the inside bearing, you clean it out and run it dry?
revo_race is offline
Old 01-11-2024, 08:39 PM
  #50
never any oil on the inside bearing. That oil will immediately go into the shoes etc and cause slip and heat and cause more problems. Ran clutches like this for 20+ years 👍
Old 01-12-2024, 05:37 AM
  #51
petersen114's Avatar
lol... I don't even oil the outer bearing.
Tony Newland and racing_jason like this.
petersen114 is offline
Old 01-12-2024, 06:41 AM
  #52
briefer's Avatar
I am sure that oil lasts a couple of minutes, at least! quite useful!
briefer is offline
Old 01-12-2024, 03:01 PM
  #53
fyrstormer's Avatar
Originally Posted by Roelof
To make it clear, I do not replace them every race but I know people who do that. With a regular lubrication even these cheap bearings can last several races. But if you have expensive bearings you want to extend the life, with 20ct bearings there is no need to think about that.
Longer lifespan also means less maintenance. I have other things I have to do on a daily basis too. Finding time to tinker with my RCs gets harder every year.
Tony Newland and petersen114 like this.
fyrstormer is offline
Old 01-12-2024, 08:04 PM
  #54
agreed same here. The last couple years i usually run the whole weekend on what I showed up with. The days of wrenching half the night etc are long gone. If you want to find out how to the get the most out of every piece I’m your guy haha
token likes this.
Old 01-13-2024, 01:19 AM
  #55
stanleyw808's Avatar
Hello Tony Newland,
How about when we use Vented Clutch Bell? If there is an excess oil, it will fling out right away through the Bell Opening.
Cheers..
stanleyw808 is offline
Old 01-13-2024, 07:10 AM
  #56
Originally Posted by stanleyw808
Hello Tony Newland,
Cheers..
yes if any of it makes its way through the shoes etc it will exit the bell through the vents. But the point is to not send oil or grease through the shoes and clutch bell surface where it creates slippage and heat 👍
token and stanleyw808 like this.
Old 01-19-2024, 06:28 AM
  #57
Big Mike 214's Avatar
following
Big Mike 214 is offline
Old 01-24-2024, 05:04 AM
  #58
kruzracing169's Avatar
So I have been using Avid ceramics as I mentioned above.
I feel like J&T has gone the distance it seems here in the last year or so. Like what I mean, pushing it and bringing it some good products.
I will give them a try on the bearings.
kruzracing169 is offline
Old 01-24-2024, 06:55 AM
  #59
Yeah I’ve gone well over a gallon on avid clutch bearings for years. Haven’t found a reason to try any of the new comers to the category. $4 per gallon in bearings? Holy smokes what’s that equate to per tank? $.13 per tank lol
