Novarossi carburettor on wrong side >
Old 04-18-2010, 01:09 PM
Default Novarossi carburettor on wrong side
Hi,
I just bougth this Novarossi engine:
http://www.jespares.com/nitro-models...4&keyword=2010
The carburator is on the wrong side and when I install it on my XB808 it doesnt seem to fit right. I am new to this so please help
Jaap is offline
Old 04-18-2010, 01:13 PM
yuppi1's Avatar
hi have had no experience with that motor but is there any reason why you cant take the carby off and turn it around?
yuppi1 is offline
Old 04-18-2010, 01:17 PM
To be honest I have never even started a nitro engine in my life let alone change the carburettor. I will try if I know its possible
Jaap is offline
Old 04-18-2010, 01:21 PM
shanty140's Avatar
What you need to do is loosen the pinch bolt that holds the carb on the motor. Then gently pull the carb off and turn it the right way. Make sure not to tear the O-rings on the carb when you pull it on and put it back on.
shanty140 is offline
Old 04-18-2010, 01:24 PM
yuppi1's Avatar
Originally Posted by shanty140
What you need to do is loosen the pinch bolt that holds the carb on the motor. Then gently pull the carb off and turn it the right way. Make sure not to wreck the O-rings on the carb when you pull it on and put it back on.
+1
also just take your time and be patient, you will it get it
yuppi1 is offline
Old 04-18-2010, 01:43 PM
Thank you all for your help....I just did it like you said
Jaap is offline
Old 04-18-2010, 01:57 PM
houston's Avatar
Trader Rating: 96 (100%+)
put oil (non petroleum , synthetic) on any area where there is an oring when reassembling . what kind of engine ? does it hapen to be novarossi n21r limited?
houston is offline
