NEW AGAMA A8 BUGGGY
#6871
first outing with the agama very tail happy any ideas how to rectify this it seem to run from the rear felt like a 2 wheel drive at time lol the track wasnt the best no fault of the organizers money and time and weather u get the drift the setup i used was the stock out of the box the diffs shimmed as per gene 3k 3k 2k fcr also 8 hole 1.3 pistons 37.5 front 32.5 rear losi oil short shock ends .9 cluutch springs and 17 tooth bell grey springs sway bars stock battery at the front tire med ibeams temps were 38c and she seemed a little twitchy
any help would be greatly appreciated on the rear tail happy lol
#6873
Shane, I thought I sent you my set-up? The box set-up is pretty useless. Mine is not a pro set-up but it makes the car really easy to drive and it's very stable. Once you learn the buggy you can tweak it from there. I'll PM it to you. Battery has to go in the back, and you need thicker diff oils and you have to lay down the rear shocks a bit.
#6874
+1 on that, the stock setup would make you believe the car is ass happy. Try JB or AB setup and you should be fine. I'm sure James setup would be even better because I'm assuming it would be a little less aggresive.
#6875
#6876
Sure thing Bud. Anything is better than the box set-up.
Shayne, you may want to go to the Hobby pro USA website and look over the pro's posted set-ups. There may be something that is better suited for the track type you run on. Most tracks here in AZ are high traction and high speed with very large jumps so that's what my buggy is geared towards. I'm interested to see JB and JK's set-ups when they come here next month to see what the major differences are between my set up and there's.
#6877
has jeremy kortz posted any of his setups yet?
#6878
anyone know where i can get the optional steering rack for the evo. on the site it just has the ackerman plate
#6879
It was about useless anyway, unless you run oval or a 1/5th track. You can put the shorter ackerman on to get less throw on the outer wheel if that's what you're looking for.
#6880
wow guys im impressed with the replies makes me feel welcome
im in aus lol so had a surprise wen i turned the comp on this morning
thanks again! as for jaz yea dude i got the setup thanks again buddy and ill have a look into wat has been suggested but i will be honest the track was horrible for grip and smoothness through no fault of the club i will say this the car is amazingly aggressive lol need to bring me smooth finger next time lol!
#6882
Ok would like suggestions on how I should set up my back up buggy. I want to make it close to the same as main but have some differenced like diff fluids. Shock fluid and geometry of links.
