Best V-Spec pipe
I run a JP-4 on mine just got my V-Spec and JP-4 Runs really well not 100% sure on what fuel milage I get but was pritty good!
OS 2060 or 2050, if you don't want to spend that much the losi re11 is a direct copy of the OS 2050.
http://losi.com/Products/Features.aspx?ProdId=LOSR8001
Suspended
re11 is dialed i catch speeds with that pipe and motor
all of us that have v-specs rub the RE11 pipe here, because we run 10 min heats and if you pit, you run the chance of not having a good qual spot.
I can get almost 11 min w/8mm restrictor on mine.
