Smoke Coming out after corner >
Old 09-13-2009, 06:11 PM
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Smoke Coming out after corner
If there doesnt seem to be enough smoke coming out thru a corner which is a big thing to have, should i adjust the low or high speed. Im guessing the low speed. And should i richen it or lean it out to create more smoke. Im pretty sure i should richen it but then does that mean i have to adjust the high speed once i do that?
jhipps835 is offline
Old 09-13-2009, 06:15 PM
smokinu's Avatar
Trader Rating: 82 (99%+)
when in doubt lean her out.
all kidding aside if the motor is making good power and still has some smoke and temps fine leave it alone.
smokinu is offline
Old 09-13-2009, 06:20 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
With a name like that, I would listen to him
Smoke depends a lot on the fuel. Fuels with lots of castor will smoke more than a low oil content, mostly synthetic blend.
wingracer is offline
Old 09-13-2009, 06:37 PM
jhipps835's Avatar
Well after running a couple laps it was at 240. So if there is no smoke out of corners i shoud lean the low speed?
Old 09-13-2009, 06:39 PM
unsp0ken's Avatar
Trader Rating: 25 (100%+)
leaning any of the needles will reduce smoke.
unsp0ken is offline
Old 09-13-2009, 06:40 PM
smokinu's Avatar
it was a joke richen the hsn 1 hour to 2 hours.
smokinu is offline
Old 09-13-2009, 06:41 PM
MotoGod's Avatar
Trader Rating: 118 (100%+)
Rich = More Smoke, Cooler Temps
Lean = Less Smoke, Higher Temps
I would richen the HSN by 1-2 hours and see how it reacts to start. Every engine/tune is a bit different. The HSN controls overall fuel delivery to the engine though. The LSN only controls fuel delivery at idle to maybe 1/2 throttle or so.
Either way....you need to richen something if you wanna see more smoke ;-)
MotoGod is offline
Old 09-13-2009, 06:48 PM
jhipps835's Avatar
Ok thanks
Old 09-13-2009, 06:49 PM
jhipps835's Avatar
I just figured since you were coming out of the corner at LOW SPEEDS you would be adjusting the low speed needle. I know the the richer it is the more smoke
Old 09-13-2009, 06:53 PM
revo61's Avatar
Trader Rating: 18 (95%+)
Don't tune by smoke. After a 5min run, what are your temps like? By the way what engine are we talking about, some engine run better at higher temps. What brand fuel and is it 20 or 30%?
revo61 is offline
Old 09-13-2009, 06:57 PM
wingracer's Avatar
Low speed needle is really a bad name for it. It should really be called an Idle Mixture adjustment. Speed doesn't really matter. The moment you open the throttle, the needle pulls out of the seat for the LSN and now the fuel is only restricted by the HSN.
Old 09-13-2009, 06:59 PM
smokinu's Avatar
very true and 240 is a perfect temp for any motor
i think he has a v spec btw!
smokinu is offline
Old 09-13-2009, 07:09 PM
jhipps835's Avatar
Yes i Have a v spec. Came off at 240 and i believe it was longer than 5 minutes. And im running byrons 20% fuel. So does it seem good like it is?
Old 09-13-2009, 07:11 PM
revo61's Avatar
Thats fine.
revo61 is offline
Old 09-13-2009, 07:21 PM
MotoGod's Avatar
Yeah the LSN only has an effect on the mixture until the needle on your carb slide comes all the way out of the slot it's seated in. Once it's out...HSN is doing ALL the work for mixture. Some carbs the needle is fully out by 1/4 throttle...others...1/2 throttle. Just pull your air filter off, turn on your rig....and operate your throttle and make a mental note of when the needle pulls completely out of it's sheeth. When it's out....any throttle position LESS than that is the LSN kicking in....anything MORE is the HSN.
More guys mis-tune their low speed though.....
MotoGod is offline
