Bluebird servos - Are they crap?
I'm considering this Bluebird 821DMG+HS servo to replace the throttle on my 8ight-B 2.0 RTR.
Any comments?
Any comments?
Maybe I had bad luck, but I've used 3 of their servo's...
2 mid range ones used for throttle, both only lasted 1 race meet, died...
1 high end steering servo which I loved for a while, but after 5-6 meets it also died...
(none were the same model as you listed though)
I've had one Ace and one Futaba servo since with no sign of any problems...
I'm defiantly a beliver in buy 2 decent servos instead of 6 crap ones.... NOW
It really does work out cheaper in the end.
Havent looked into the ACE servos yet but I've seen the name frequently. I'll look into those as well.
I just need to be as efficient with money as I can an still get some decent upgrades. I will get good stuff where I need to for steering, tires, etc. But I need to try and scrimp where I can...
How much beating does the throttle take?
servo
Dont spend the money on the Bluebird stuff, but the ACE servos are good I have had a Associated 1015 in my car for 2 years and I race every week. The ACE 1015 is the same servo but they are not cheep $99
I have used them - The higher Torque metal gear ones. Bought Two, they lasted almost a season of indoor 1/10th scale offroad. They have two year warranty - so i sent them in for warranty and they replaced them in about a two week turnaround.
I have since switched to Hitec - Good servos, Good Warranty.
Hitec :
Get this one for throttle;
http://www.amainhobbies.com/product_...tal-Gear-Servo
And this one for Stearing:
That's as cheep as I would go
Hitec :
I would bite the bullet and spend a little money and get the following:
Throttle:
Hitec HS-7940TH
Steering:
Hitec HS-7950TH
Buy these and you won't need to buy another set for sometime. Fast, Strong , High Voltage(lipo receiver pack) and great warranty.
Throttle:
Hitec HS-7940TH
Steering:
Hitec HS-7950TH
Throttle:
Hitec HS-7940TH
Steering:
Hitec HS-7950TH
If/when I get good enough to be competative, those will be the ones to move up to.
Hitec 985 MG $69 .13 at 6V just type in 985mg in the a-main search I know alot of people that run this servo in both steering and throttle and when they blow you have the no question asked warranty of Hitec
