V Spec Breakin
breakin
During breakin you want the temps to be around 200. Adjust needles according to the temp. Also use tin foil to put around the head to keep the temps up around 200. Too low of temps are just as bad as to high of temps. Keep it around 200 might have to lean it out to get to that temp but its very important to keep the motor at 200 during breakin also make sure you put the piston (bdc) bottom dead center while you let it cool hope this helps and good luck
I couldnt even get my engine started with tin foil and the engine heated up to 240 degrees at first. I had to lean the LSN about 1/4-1/2 of a turn to even start. But, the needle settings will be alot different from somone that runs indoor in PA than someone who run outdoor in 110+ degrees in socal.
Buy one.
Here you go:
http://s453.photobucket.com/albums/q...t=103_7736.flv
Too rich or Too lean? Let me know
Here is the link, not sure if the other worked:
