V Spec Breakin
How rich should i be running my V spec from Factory settings? The hsn is 3 turns out at factory so how much further should i go to break it in? Im hoping someone with a v spec could let me know.
breakin
During breakin you want the temps to be around 200. Adjust needles according to the temp. Also use tin foil to put around the head to keep the temps up around 200. Too low of temps are just as bad as to high of temps. Keep it around 200 might have to lean it out to get to that temp but its very important to keep the motor at 200 during breakin also make sure you put the piston (bdc) bottom dead center while you let it cool hope this helps and good luck
I use factory settings for break in on all of mo OS's.:nod:
Originally Posted by JAMMINKRAZY
(Post 6208963)
Ok the thing is i dont have a temp gun. What should i do then?
I have a video uploading now. So ill let you guys here how it sounds and you can tell me then.
Originally Posted by Chris__RC
(Post 6208973)
I couldnt even get my engine started with tin foil and the engine heated up to 240 degrees at first. I had to lean the LSN about 1/4-1/2 of a turn to even start. But, the needle settings will be alot different from somone that runs indoor in PA than someone who run outdoor in 110+ degrees in socal.
Originally Posted by jhipps835
(Post 6208983)
Here you go:
http://s453.photobucket.com/albums/q...t=103_7736.flv Too rich or Too lean? Let me know |
you should get one...really...and a heat gun..especially if you plan on buying high dollar racing engines...its a $50 total investment to protect thousands of dollars worth of engines over the course of your racing career
Originally Posted by Jaz240
(Post 6208993)
Oops sorry i mean i dont have a heat gun. I do have a temp guage. I just use a hair dryer instead. Sorry about that. How does it sound?
(Post 6208999)
A temp gun is a nice tool to have also. Just try not to catch yourself tuning by temp.
By the video there is no way to tell. I would say blipping the throttle like that is worse for it than running long slightly rich runs up and down the street.
(Post 6209007)
It's really worth the $30 to just buy a heat gun. A hair dryer will NOT get the engine core hot enough.:nod:
Here is the link, not sure if the other worked: http://s453.photobucket.com/albums/q...t=103_7736.flv |
