CLUTCH SHOES--LEADING or FALLOW??!!?? >
Old 07-08-2009, 11:31 PM
  #16
I dont know how you define snap but if you dont change other things & just turn your shoes around you'll get bog,meaning your shoes will engage at lower RPM & lock almost solid almost immediately. Just try it & see what you think,only cost you an hour of your time to see if you like it or not.
butch man is offline
Old 07-09-2009, 01:05 AM
  #17
No the springs determine when they engage not the way the clutch shoes are installed. Yes installing them leading once they grab they wedge/lock into the bell hard with no slipping with alum shoes.
pdmustgt is offline
Old 07-09-2009, 03:09 AM
  #18
fleggasaurus's Avatar
In regards to grass racing and using a losi 4 shoe setup, how do you think running 2 aluminium shoes in the normal way with gold springs and then running 2 carbon shoes as you call leading with gold springs go???
We race on grass and our tracks are built from transported piping so the tracks are never huge and have plenty of sharp turns.
fleggasaurus is offline
Old 07-09-2009, 03:56 AM
  #19
CHogle's Avatar
i always run mine trailing, their more consitent and the shoes will last longer. not to mention the light stress that you engine will experance compared to leading your shoes.
on my d8 ill run carbon shoes indoors 99% of the time
ill run alumiums outdoors to give the car a little more grunt
CHogle is offline
Old 07-09-2009, 04:05 AM
  #20
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
You can mix and match shoes and springs... but you can't run half one direction and half the other... it just doesn't fit that way.
DOMIT is offline
Old 07-09-2009, 05:06 AM
  #21
swede8ight's Avatar
Run your Losi clutch with 4 carbon and gold springs leading. Perfect engagement, shoes and bearings will last almost forever. Polish the clutch bell inside before running.
swede8ight is offline
Old 07-09-2009, 10:13 PM
  #22
pdmustgt when you turn the shoes around it changes the leverage the shoes have on the springs because of direction of rotation. The no slip factor also has more of an effect on enguagement feel. I dont think people realize how much clutch shoes slip during normal trailing use. I never tell people to take my word for it just spend the time to try & you'll se what I mean. It makes a 5,000-7,000 rpm difference coming out of corners.Your eng will bog badly if you change nothing else.
