Ofna Ravager Tire/Wheel Question >
Old 06-25-2009, 08:02 PM
Default Ofna Ravager Tire/Wheel Question
Just wondering if I can put truggy sized tires and wheels on my Ravager? Do they bolt right on or are there things I need to buy to do a conversion? I just use it for a beater.
BlackSS is offline
Old 06-25-2009, 08:16 PM
pyromania's Avatar
Trader Rating: 18 (100%+)
Yes you can, but your clutch will not last. Truggies have different gearing and that's why they're able to run lager tires.
pyromania is offline
Old 06-25-2009, 08:50 PM
Will I need wheel spacers or anything?
Also, I will change the gearing. What should I run for playing around?
BlackSS is offline
Old 06-26-2009, 04:28 AM
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Hmmm... not sure if the tires will clear when you turn... running 1/2 offsets should help.
You could get the center diff and mount from a Jammin X1CRT, it has ummmm... a 62 tooth spur gear I think? You could probably get by with just the spur gear and the spacers for the center diff mount, and longer bolts of course... but I'm not absolutely positive they will interchange.
DOMIT is offline
Old 06-26-2009, 08:00 AM
Does anybody else know if the truggy tires & wheels will fit for sure? And what else I need?
BlackSS is offline
