DREAUX'S PERSONAL THREAD
#241
first off. Sorry chris, wans't trying to be a smartass.
second off. I was taking my muffler off to cleand it, and was noticing the pinch on my motor. When i turn it, it still has compression, But not as much as before. Quite a bit less actually. You can forget a 6 second flop test. Is this because i finally got it running right and it has expanded properly. I have about 2.5 gallons on it. I have had it for about a month. After i broke it in, It was off and on with how it ran. I had a hard time getting it to run right. It had alot of compression the whole time (like 2 gallons). Now i have had no problems and it has started right up and kept it's tune. Is it normal to have this little of pinch?? How much pinch should i have?? I know this is quite hard for anyone to answer. I am just concerned i guess. How much does your engine have?? I know i sound crazy huh?
#244
Will alumium shock towers effect the performance of my mugen6, I had a crack in the front one. THe rear is still carbon but the wing stay gets most of the shock, so i bought another one of those too
#246
so i should have just got another carbon one. I misunderstood. So basically i would have a bent tower right now. But i could still use it. How easy do they bend. THere not as tough, that is a dissapointment.
#247
Ok. I am getting a new pipe. So I want to know something.
Polished VS Anodized, what are the pro's and con's??
Had a anodized 086 was thinking about a polished one this time. And it is cheaper
#248
#249
#250
If you broke the carbon, you would have bent the aluminum so bad you would not been able to bend it back...you know what happens to metal when you keep bending it back and forth....snap....Use the aluminim if you bought it already, when that one goes..get the cheepest one..you'll be replacing them allot until you stop landing on your tower
#251
if you bend metal back and forth it will snap. its called a fatigue crack or something like that
#252
got my towers today. They are a good bit thicker then the carbon ones, and to me they weigh about the same. I will let you know how it performs. I am getting to be a good driver really. I have had some bad landings of ramps but thats about it. I have learned how to control my jumps now.
#253
I am changing oil in my shocks. Can someone give me some advice on what shock oil would be best. I have been running the stock setup on my mugen (450), maybe someone can explain what lighter oil in the front and heavyier in the rear and visa versa will do. Even the hudy book doesn't really explain it, it says to change the pistons. any help is appreciated. I have 250, 300, 350, 400, 450, 900. I will fidle with the pistons later if necesarry. Would like to mess with the oil first. Overall though my car drives and corners well. But would still like to know.
AND YES I HAVE USED THE SEARCH FUNCTION.
#254
going to use 400 in the rear and 350 up front
