Fuel coolers, gimmick? or actually work?
I've see few coolers from integy as well as others
http://www3.towerhobbies.com/cgi-bin...&I=LXXCF5&P=FR
Like this one above..
I could if If they really did work, it could lower engine temperature,
any one tried this?
any one tried this?
I am not sure why they are marketing it as a fuel cooler when RB and NovaRossi brought out a similiar looking item for cooling the exhaust gases coming from the pipe into the fuel tank. Supposedly it helped when the 1/8 scale onroads were struggling to make runtime in qualifing without running out if fuel in the high outside temperature.
any one tried this?
any one tried this?
It adds a heatsink to the hot exhaust gas traveling from your muffler, to the topside of the fuel tank, which keeps your fuel cooler...and gives you better fuel mileage. I run the Novarossi ones, it's a great product...especially if you live in a hot climate.
That not what theyre designed to do.
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
by lowering the exhaust temp, you're lowering your pressure by ideal gas law pv=nrt
you're just making your engine run leaner, using less fuel by lowering the tank pressure.
however if you cool the fuel going in to your engine it can have dramatic effect of lowering your engine temperature. and liquid do not not change volume drastically with change in temperature.
but it really depends on how much it can cool fuel, if all it does it 1 or 2 degress it's worth less, but 10 degrees? may be worth considering.
I dont' see how this is beneficial,
where they were originally tested, people were getting an extra 60 seconds of runtime.
And im pretty sure you have it wrong...its not lowering the tank pressure, its just pressurizing it with cooler air...thus transferring less heat to your fuel before its picked up and transferred to the engine.
Its a terribly simple concept to grasp, I don't see how people cant connect the dots
they help to keep your nitro in your fuel and not in the atmosphere, i do it the cheap way with 2 fuel filter's
QUOTE FOM THE novarossi webpage
"The secret behind the 'EGC' is as the name suggests removes some of the heat from the exhaust gas that returns to the fuel tank via the pressure line from the pipe. This lowers the temperature of the fuel and thus increases the runtime."
it COOLs the exhaust temperature, I'm not saying novarossi is lying, but what you're saying is that their product defies physics.
Their ULTIMATE goal is to lower the fuel temperature, so concept is the same, let's not argue about who's right or wrong.
if what you say is true, to be able to get extra 60sec of run time, that's significant.
WHOS wants to volunteer in recording temperature and run times??
looks liek integy and novarossi is exact same except in price.
really it's not rocket science, nitro (the alcohol specifically) has a low boiling point and actually is evaporated into the atmosphere by the hot exh gasses. so all you need to do is cool the exh gasses and you will see better performance/mileage
The funny part the carb gets cold when fuel is atomized.
I don't know if they work or not but I don't really agree with the pressure loss thing. If it were a closed system I would agree with it but it isn't. The pressure coming from the exhaust is the same so if any pressure was lost in the tank, more would come from the exhaust and equalize it. If it worked the other way you would have a lot more hot water pressure than cold in your house.
