Methods for cleaning/lubricating bearings?
#16
Dont listen to this dude. No matter how pretty the wrapper is or what materials they are manufactured from, forgetting bearing matinence is ignorant. I like ANY bearing with two rubber seals. They keep dirt out better and are easier to take apart to clean. I clean them about every 1/2 gallon with brake or carb cleaner and compressed air until they spin fast without chattering or sounding gritty. If they never do clean up i will replace them. I usually find the start of a problem before it gets bad enough to cause a DNF.
I repack them with automotive axle grease then blow the excess out with low psi compressed air. Put the seals back on and put them back in the car. Sometimes I will take the seals off the inside-side of the bearing in the hub carriers. $1.00 bearings are a good idea for a supply of spares.
1st weekend (brand new bearings)
2nd weekend (take out lube all bearings and clean out grit)
3nd weekend (clean them, then toss them in a ziploc bag with wax lube)
start the cycle all over again. its just good habbit. if you dont maintain your machine, you will be fighting your machine the whole race. having a maintain rig will always reward you later. (less broken parts, less blown parts, etc)
#19
#20
Funny. Try the Boca's. Take them out, wipe them off, and put them back in. Not here to argue or only push my sponsors. A guy asked for some advice and I gave it. YOU WON'T BE DISAPPOINTED!!!
If you don't believe me then keep taking 20 some bearings apart, degrease them, air blast them, re-grease, put back together and reinstall. Been there and done that. I'll stick with my yellow seals..........
#21
I want to try some avid bearings in my 8ight rtr but I dont know what size it needs. Also what type and size bearings woulld I need for my motor and clutch?
#22
5x13 for inner clutch
5x10 for outter clutch
8x14x4 for outter wheel bearings
1/2"x3/4" Inside wheel bearing
8x14x4 Flanged for diffs
6x10x3 for steering rack
5x11x4 pinion bearings.
i think thats it.
#23
#24
So how often do you replace your bearings? I got my 8ight used and ive drove the car a couple weekends doing my maintence on them every week, and they still spin freely without any noise.
For some reason, right after I clean my bearings with motor spray they feel gritty. Then when I lube them they feel smoother. Why is this?
#25
rgrassey has a 8ight t if that makes a difference.
#27
I think, when the bearing gets dirt in it, it scatches the inside of the bearing.......then you clean it all out and you can feel the scatches on the various parts in the bearing. Then when you put in the oil it helps fill the scratches and the bearing feels smoother........
#28
ball bearing maintenance
We know that hardcore racers maintain their bearings and for good reason: racing requires oiled ball bearings NOT greased ball bearings. Greased bearings will not feel gritty as soon because the heavy grease dampens the noise caused by tiny dirt particles BUT it also severely slows the bearing down. So they will still have grit or dirt in them you just wont feel or hear it as much, making you think that cleaning is not necessary. For racing, greased bearings are okay for the clutch area but not for wheels and transmission as they will slow down the car.
Furthermore the tighter the bearing seal is around the ball bearing inner race the more it slows the bearing down.
If you want to go fast you must use an oiled ceramic bearing (like ACER Racing Ceramic Nitride Pro Series bearings) with a properly engineered bearing seal tolerance that strikes a perfect balance between keeping out the elements while allowing free rotation of the bearing.
If necessary, clean with RPM bearing blaster and motor cleaner without removing the seals BUT make sure to wait for it to dry before relubing with a fully synthetic ball bearing oil (NOT grease) like ACER Racing SIN lube. Not waiting for it to dry will cause the motor cleaner to eat away at the lube leaving a dry ball bearing.
Hope this helps!
ACER Racing :
THE Fastest, Smoothest, Lightest and HARDEST Balls in the INDUSTRY
Hope this helps!
ACER Racing :
#29
7.99$ a Each ....Ill keep my "slow" grease filled 1$ a piece bearings thank you.
#30
