Hot Bodies D8 Truggy
#7546
Dmain i have the same issue and found this last weekend that Slow is Fast(too a point). but when someone is catching me i want to wing the throttle .im running the axial .28RR with a Nova Rossi .21 carb and 8mm restrictor and still have serious throttle . i got a long ways to go but this weekend has been my best so far. intill the I-Beam Got in my way on a jump ruined my day bent a drive axle,broke an a-arm , and the lower shock end and the hobby shop only had parts for the buggy hardly nothing for the truggy.
#7547
#7548
really........ i got 2 Novarossi 5p .21 that i rebuilt in the box as back up motors Think ill try that as well. wont hert anything
#7550
thanks ScottyM Now that i think about it that .28 does have a lot of low end , Im going to bolt 1 of my .21's and give it a go this weekend. along with a 2.3 sway , and drop to the white springs and play with tires .
#7551
hey guys.. doing a little spring cleaning.. and although i have the D8 for 2 years i have notice this..
but doe stem rear shock tower lean forward a little??? mi leans forward and the chassis looks straight.. as a matter of fact with a straight edge on it it is straight...
#7552
Strip it down and Double check the tower isn't tweaked, If not check the bulkhead to a Brand new one for anything that doesn't look right.
#7553
Hey guys, looking to put a large fuel filter on my truggy. Any suggestions and I'm also curious where to mount it? I have a Novarossi silver one strapped to the side of the tank, but want something BIGGER. Thanks!
#7554
If you wanting to play with sway-bars, most hobby shops carry wire product from K&S.
Take your calipers with you and measure the wire in mm's as the wire is labled in standard size.
Use nails in a board such as a 2x4 and bend the wire to form your own sway-bar. Use the old bar to trace the inner and outer part of the bar to get the bend as close to stock as you can. Once bent and to you liking, cut off the excess.
You can also use angle-iron-steel with c-clamps but many probably don't have that laying around.
#7555
#7556
My laptop is acting dumb and will not let me hook my phone up but i took the fuel filter mount and fuel filters from a O'Donnells. I used trottle spacers and screwed it on from underneath. Sent you a pm.
#7557
Here they are
#7558
Here they are
Hope this helps.
Hope this helps.
#7560
I ran o'donnells for 3 years or so I have incorporatec a few things into the d8t.
