Kyosho dogbone pin replacement.
Anyone know what size pins Kyosho uses on the dogbones? I'm trying to replace the worn pin and can't find the right size. I have the Hudy pin replacement tool and have been doing it on the 8ights, ofna, and mugen which all uses the same size pin.
Kyosho MP-6 uses 2.89mm pins. I have not found a replacement for them. I wear mine flat on two sides so I have pressed them all out and rotated them 90 degrees and pressed them back in and will be fine for awhile. I have contacted one of the only companies that offers custom made dowel pins. They replied to my e-mail the same day and asked me a couple of questions. I sent them back the info two days later and have not heard from them in about two days
Otherwise you would have to get an 3mm undersize reamer and ream out the bones and buy standard 3mm pins. More work
If I get any useful help I'll try and post here. I don't think Kyosho wants you to do anything but keep buying new complete dogbones
Have you rotated yours yet? If you only wear yours on one side, take the bones out, rotate them around 180 degrees and put them back in. If you wore out two sides (braking and accellerating) press the pins out and rotate them 90 degrees and press them back in for now.
Hopefully someone knows more than both of us do!
everyone uses Mugen pins for CVD's...there All 3mm.
I've got a Kyosho STRR but I think it is the same size u mentioned. I did turn the pins 180 degrees already. I was stubborn and tried pressing in a 3mm pin and ended up cracking the dogbone.
FYI I am waiting on these guys...
http://www.test-x.com/
On the left go to Fixture Hardware then Dowel Pins. Maybe you can get a quote out of them for price and minimum quantity you need to order. You want custom made 0.114" diameter by 0.551" (check the length first on a STRR) with a Rockwell C hardness of about 55. Let me know if you get anywhere. Maybe I caught them on a slow day the first time and they will get back to me next week
Should be a lot cheaper than buying new dogbones twice a season
The pins on the STRR are the same dimensions. I just emailed test-x so we'll see if they respond.
KIK - I just noticed that the first email to testx went to a different e-mail than the ones he replied with. Maybe the reason for the repsonse time. If I haven't heard from him by Wed. I'll try the original web site e-mail again.
I emailed them couple days ago and I didn't get a response?!?!?!
I tried the original web site e-mail again yesterday with no response yet. The response from the AOL e-mail had his name and phone numbers. I'm debating calling them tomorrow because I will be out of the country for a couple of weeks. I don't need them until the middle of the summer so I can just as well wait. I'll be able to correspond e-mail and here the whole time so if you get impatient and there are no phone numbers on the web site I can PM you his contact information.
