8T 2.0
#6736
LOSA1734 is the same as LOSA1711 except for the color, both are inclined 10 degrees. LOSA1733 same as LOSA1706 except for the color, both are 12 degrees. They also make a complete 12 degree set now, part # LOSA1728. The new black color scheme on these parts was introduced when Losi released news of their European Edition buggy.
www.overdriverc.com
www.overdriverc.com
#6737
I'm going to stand by my statement, I'm looking at LOSA1706 and LOSA1733 right now. Sorry to say but I don't see any difference whatsoever except for color. Well, Horizon assigned different names to them too.
#6739
Thanks I have the new style then I remember reading back a few pages that their were issues with the pins popping out was that the old or new setup?
#6740
Inclined...
http://losi.com/Products/Features.aspx?ProdId=LOSA1728
http://losi.com/Products/Features.aspx?ProdId=LOSA1729
http://losi.com/Products/Features.aspx?ProdId=LOSA1733
http://losi.com/Products/Features.aspx?ProdId=LOSA1734
Not inclined...
http://losi.com/Products/Features.aspx?ProdId=LOSA1706
http://losi.com/Products/Features.aspx?ProdId=LOSA1708
http://losi.com/Products/Features.aspx?ProdId=LOSA1711
Notice the INCLINED in the description of the first four.
I hope that will clear it up a bit for those who still don't understand.
Not inclined...
#6741
Inclined...
Not inclined...
Not inclined...
Let me ask you something, if the difference in incline between the older carriers and the newer carriers is not caster (as you said yourself caster angle is represented by the 10 or 12 degree designation) then what is it? The only two other axis are toe and camber.
And I'm still standing by my first statement.
#6743
Look at the top where the upper camberlink mounts. The new inclined black ones the bolt is horizontal just like the stock plastic ones. The old style silver aluminum ones the bolt is vertical and you add shims to adjust camber gain. The caster is still the same whether its 10* or 12* respectively, that is measured in relation to the lower hingpin holes, on the new hubs the kingpin hole has been angled 5 degrees, but the angle of the carriers in the hubs is the same.
For those that think they are the same then don't buy them and you can follow or try to follow the guys that buy them around the track as everyone I have talked to running them says they will be a very popular item no matter the cost.
Drake and Truhe said they are always testing and trying new stuff, when they tried these, it was noticably better instantly.
So if you don't want them, don't buy them, but don't sit here and argue about it either. I will try and post pics of both when I get home as I have both, but I am also packing to go out of town racing tonight.
#6744
"Inclined" in the name refers to front spindles and not spindle carriers we were talking about. It's the carriers that bear 10 degree and 12 degree marks, the front spindles are identical, once again except for the color. In fact, I have both the new black ones and the older pewter color front spindles in my hands right now and there's no difference (save for color).
The incline actually refers to both the spindle and carrier. There in fact is a difference between the black pieces and the gray pieces(both spindles and carriers). The incline has nothing to do with caster(the inclined carriers still have caster angles of 10 and 12 degrees). The incline is in a different axis than the caster is. If going by the axises you described, it is on the "camber axis". This doesn't mean that your camber will be any different however.
Think of it this way. We'll say the stock king pins are in a completely vertical position on the standard spindle/carrier. With the new inclined spindle/carrier that vertical line has been rotated/tilted 5 degrees. In doing so the king pins are now inclined 5 degrees. You would think that would change your camber correct? Wrong! The spindle has been re-shaped in a way that your camber setting can remain what it was, but you still have an extra 5 degrees of inclination in the king pins.
I hope I got that right above^^ But I can tell you FOR SURE that there IS A DIFFERENCE!
#6745
LOL I guess we were posting at the same time. I type slow!
#6746
They are different..... I have both sets in my hand right this second, well in front of me, If you look there is a difference. And they are a must have - big difference in how the car handles in the turns.. both in and out.
#6747
Maybe this will explain it better...
The angle of the Axle/Hex hub/Wheel+tire remains the same, but the king pins are inclined an extra 5 degrees. Is that less confusing?? I don't know if I am explaining it well, but there is in fact a difference in both the spindles and carriers.
BTW I would let someone at that Overdrive place know that their descriptions are wrong on the old gray parts(LOSA1711 and LOSA1706) as they aren't in fact inclined.
#6750
I tested them last weekend and the control was better throughout the corner. I was able to make more controlled passes with less out of control rotation and more linear steering. I even had a brief moment of brilliance where I made an inside pass around a 180 leaving the truggy I passed slower and on the outside without touching him, it was beautiful and even got cheers from the crown. IDK if I could have made that move with such precision without the inclined parts. Bottom line is I like them and the difference is even more noticeable in the buggy. I just feel like I am in more control through the corners.
So is LOSA1729 spindle the same spindle that is in the LOSA 1728 set?
