8T 2.0
#5611
Hey guys another quick question.
Does the Race roller come with the V2 towers? Also what is the Big difference between roller and the RTR? I know the Roller you build yourself but what I’m getting at is parts wise? Also does the RTR have the pins to remove the radio tray like the Roller? Does the fuel tank remove on the rtr like the roller? just trying to see what are the main differences thanks GUYS!!!
#5612
No the V2 is a hop-up not standard tank and radio tray all the same biggest upgrade from RTR to Roller are the chassis and shock towers.
#5613
The main difference between the roller and the RTR is the chassis, shock-towers, bottom/top shock caps and some other parts. Everything on the RTR is mounted the exact same way as the roller.
What pins on the radio tray are you talking about?
#5614
I'm in the process of setting up a spare motor for my cars. I'm running the losi quick change mounts both.
One of them is an 8B version one and the other is a 2.0 truggy.
Will the 2.0 flywheel be ok to use on the 1.0?
If this is possible then it is just a matter of throwing a clutch bell on the motor and dropping it in the car
#5615
The roller doesn't come with the new tower, but it may sometime in the future. The roller comes pre-built, but it's best just to go over once and make sure everything is right.
#5618
Hey guys quick question. What does the set screws that put pressure on the sway bar do. Do they effect the performance? I noticed my front one is really tight and the back has all kind of play as they are backed out. Thanks....
#5620
how much back and forth play do you have on your sway bars? just a tick of play.
on a rough blown out track should, the sway bars be fully loose but not enough where the set screws fall out?
#5622
The sway bar set screws are there to adjust the amount of play when changing to different size bars. The sway bars should ALWAYS MOVE FREELY with just a bit of slop.
#5623
Before you connect the sway bar links, tighten the set screws until you feel friction on the bar while moving up and down through the travel. Back the set screw off so there is just the slightest amount of friction. This adjustment makes the sway bar react to the slightest amount of chassis roll.
#5624
with the 2.0 bar there is a lot of slop in the saddle, does this affect it
#5625
