MBX6 Shocks on a MBX5T
Has anyone done this yet? I just got a set of MBX6 Shocks off of Ebay and I was wondering if the Springs are going to be too soft and what weight oil I should run in them for the Truggy.
I think there HoeBay truggy big bore springs that will fit.
Thanks Tony I was thinking the same thing. Do you know which st-rr springs he used. I see most of the trucks at my track are using the blue ones. Not quite sure what stiffness those are. What about using the buggy blue springs in the front and the truggy springs in the back?
My current MBX5T runs Kyo BB buggy shocks with buggy blue springs. It works fine. The MBX5T shocks are about the same length as the 777 BB shocks. The ST-RR front BB shock and springs are much longer than the MBX5T can use. Also given that the same wire size spring with more winds is softer than the same spring wire with less coils.
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Jammin springs are both a LOT cheaper and slightly larger in diameter. I tried putting Kyosho blues on my Jammin truggy and had some slight binding between the spring and shock body. (Jammin and Kyosho shocks are both 16mm inside, but the Jammin shock bodies have slightly thicker walls... just enough to make that bind happen.) The Jammin blue springs are pretty close to the Kyosho blue ones in stiffness, but I think a bit shorter (not positive on that.) The Jammin springs would probably be a slightly better choice for you.
I got my shocks the other day and I put them on the truck. The front springs feel great, but the rears are lacking the stiffness I am Looking for I had to crank the adjuster down about 14mm to get the ride height to be level in the rear. I believe Mugen has release the option springs, but I am not sure yet. I will have to look. The shocks mounted right up on the truck with no mods needed at all.
I have a set of the Mugen hard springs on the way. I figured I would see if they would work or not. I would like to not have to run another mfg springs if they are going to rub on the housings. What weight oil do you think I should run in the shocks?
nick,
let us know how that works out.Should have some big bores in a couple of weeks
I ran my 5T last year with the Jammin big bore shocks and the jammin blue springs. It worked way better than the stock shocks and red springs. Front/rear spring combos such as the font/rear jammin blue spring are designed for the jammin truggy and you neeed to be lucky to get to work right on another car. They are softer than the reds. Our tracks are always bumpy and blown out so the softer springs work better around here. For stiffness they are inbtween the mugen grey and red springs. The jammin shocks are slightly shorter than the 5T stockers. I found the limitted droop helped it turn and roll-over less.
I was thinking the same thing. I am going to try Mugen 500 for starters and go from there. I hope to get it out on the track this weekend.
