SH Z CAR
Anyone running these?? I know Dagani runs it and LRP has a rebaged version. I tried one and it seems pretty sweet so far
http://www.shengines.com/Z-CAR/HOME.htm
I have made a few tweaks on it in the steering area and the suspension and it feels like a winner!!
LRP is doing quite well here in south germany with these cars.
Suspension seems to be working really well on bumpy tracks. Steering looks very good, too.
But man, have a look at those brakes/linkages...
as swampracer said, a ton of rear forward bite but still rotates very well in the corners. Very durable as well. A couple of really good tumbles and it rolled away. Only thing I'm not liking is the pillow ball stuff. Never been my thing.
Set ups vary from one to another depending on how you drive. Personally, I run 3,3, 700wt. oil in my diffs and if feels pretty good. Don't have to go very thick on these diffs in the Z-Car as they are very efficient.
The shocks are also fairly efficient if you build them stock. If running the metal flap inside you might try using 30wt in front and maybe 35 in back.
Again, just because it works for one person doesn't mean it works for everyone. You'll just need to experiment some and determine what's best for you.
Scott- I hear ya on the pillow balls as I've always been fond of a C-Hub set up myself. However, this PBS allows more steering and seems to do quite well. So well, actually, that I'm not sure I like C-Hub set ups any longer.
triple6- The brake linkage may look odd to someone who doesn't have a Z-Car, but once you have one you can appreciate the set up and the quality of the brakes. No brake fade period. After a 45 minute main they were still good to go for more. Also remember that the Z-Car comes from the same company that makes SH Engines. Hence, the brake pads are like miniature pistons pressing on the brake rotors. Super strong and long wearing!
In order to understand the Z-Car you first must see one. A lot of the time you'll look at it and think 'wtf', but it's pretty ingenious the way they designed some of the components.
Eric sweet dude!compare it to your 8.5 for us.more or less travel?steering,and rear side bite.i dont speak me no german but at least they had lots of pictures!how about that rear arm mount,the front one,is it sturdier than it looks? i like that little clip thing that looks like its covering what should be a turnbuckle underneath.finally looks like somebody poured some new dna in the 1/8 gene-pool!you'll be shooing me outta yer pits weds!later!
Pillow ball can allow for more steering than a C Hub car, in the past. With the current crop of C Hub cars, that's not really true anymore.
The both have their weaknesses. King pins for c hubs and bent pillow balls for killing steering.
Look I don't know this Eric guy you speak of, but I will say this car was a big suprise to me and anyone else brave enough to buy it
The Z CAR has been out for a year with little support or recognition and it deserves a fair look and a thread for racers seeking set up advise and inquiries into the car. A Main Hobbies members can acquire it for 399.00. This car has flaws, parts are hard to locate,hobbypeople.net is the best source
http://www.hobbypeople.net/part/147245.asp
Also the thottle, brake linkage is not fun to set up and dial in
The shock springs suck, the servo arms are far too flexible. The Z Car seems too good to be true once you overlook and correct these problems. The Z car has one huge + going for it and that is durability, not worrying about breaking is a big plus, the plastics are virtually indestructable, but you still have to check the usual maintenace areas, i.e. gear mesh, loose hardware , radio/wiring mishaps, engine tuning problems and the list goes around the block. I really like this car and want to keep a good up to date thead going for it
current set up after one race nite:
Front end:
No Swaybar
2 roll ctr
68 mm steer rack
rear caster location
front inboard toe 1.5
full droop
2.0 pistons 70wt a.e oil
hobao grey buggy spring w/ hobao retainer with ground down sh shock ends
optional= grind lower arms for more steering
-.5 camber
3000 wt diff oil
center
diff 3000 wt
stock clutch
rear end
stock sway bar 3mm exposed
longest wheelbase
low wing position
2.0 shock piston w/ hobao buggy med grey spring
full drop
bottom inside upper arm mount
rear upright upper arm mount lower inside hole
2nd hole from the inside upper shock position
inside shock arm position
3 degrees toe in
1000 wt diff oil
Also switched to all plastic bushings, removing the rubber/ metal unit for wt savings, read this in xrc, Greg Degani recomends for dusty areas= most 1/8 races!!
Sure i left out a few but its a start
Front end:
No Swaybar
2 roll ctr
68 mm steer rack
full droop
-.5 camber
3000 wt diff oil
center
diff 3000 wt
stock clutch
rear end
longest wheelbase
low wing position
full drop
3 degrees toe in
1000 wt diff oil
Hey sand bagger email mike kazz he has been running the car since it came out and should be able to help you with the setup.
[email protected]
[email protected]
