OS Plugs
Old 07-04-2008, 07:30 AM
  #16
wingracer's Avatar
Trader Rating: 24 (100%+)
Interesting. It's been several years since I ran an OS standard plug in anything (in fact, I don't use ANY standard plugs anymore) but the last time I did they worked fine. A friend of mine still uses OS standards in his RB without problems but maybe others are not so lucky.
Easy solution to this problem. From the motors you listed as wanting to try, get the Picco with a turbo head and use OS turbo plugs.
wingracer is offline
Old 07-04-2008, 07:52 AM
  #17
Originally Posted by ezveedub
If they only sell OS plugs in Dubai, what engine are you trying glowplugs for?
Maybe the GRP .21 standard or turbo, JPX.21, Go Tech 5port turbo, RB S3 or S5.
joydude630 is offline
Old 07-04-2008, 07:53 AM
  #18
By the way are all turbo heads the same?
Old 07-04-2008, 08:10 AM
  #19
wingracer's Avatar
No, they all use the same thread but the taper/depth is slightly different. OS plugs in Nova motors or vice versa can leak.
Old 07-04-2008, 10:01 AM
  #20
zJatoRad's Avatar
Trader Rating: 38 (100%+)
i've read some people are using O.S. turbo plugs in their GRP's, my dad once used a OS p3 plug on his picco .12 red dot and it ran fine, and if you go with the GO 5 port, you will have no problems running O.S. plugs.
zJatoRad is offline
Old 07-04-2008, 10:12 AM
  #21
ezveedub's Avatar
Trader Rating: 17 (100%+)
Now I'm really lost. Your trying to get glow plugs for all those engines?
ezveedub is offline
Old 07-04-2008, 11:07 AM
  #22
Nope. Read on other forums that users have been using OS P3 successfully in their GRP, JPX.21 and the GO 5 port. So just need to decide on one of them and rest is my luck.
Old 07-04-2008, 11:58 AM
  #23
Davidka's Avatar
Trader Rating: 86 (100%+)
I think you've found your solution. If you choose a turbo plug engine you will have broader choices for which can be run on the OS plugs that are available to you.
Davidka is offline
Old 07-04-2008, 01:35 PM
  #24
ezveedub's Avatar
OK, so my point is, if you can purchase a different engine other than an OS, I can't see why you can't get glowplugs for it also. Is the importer in Dubai bringing in other brand engines only with no parts to go with them? If so, I wouldn't bother to purchase them if you have no parts available.
As for OS plugs in other brands, Go Tech, I believe, is the only manufacturer to state they use OS type glowplugs. Other than that, I personally don't swap glowplugs brands around. For some it works, some it doesn't
ezveedub is offline
Old 07-06-2008, 10:18 PM
  #25
Hey ezveedub,
In Dubai, hobby shops only sell the OS, Novarossi and JP.
Novarossi - no parts available
JP Eagle - way to expensive and its a monster
OS - everyone sells them, parts readily available
I have 3 OS engines. But really want to try something different. On the race track you will only see OS engines. So got bored.
JPX.21 no parts available on amain hobbies. I am now leaning towards the GRP or Go Tech 5 Port.
As you said, Go Tech 5 Port is the only manufacturer to state they use OS type glowplugs. But GRP does not state that and for some it works, some it doesn't.
Old 07-06-2008, 10:23 PM
  #26
Davidka's Avatar
Hey ezveedub,
In Dubai, hobby shops only sell the OS, SH, Novarossi and JP.
For what it's worth, the Jammin JPX .21 is exactly the same engine as the Picco P7r and all the parts of the Picco will fit. I don't know if that helps any.
Davidka is offline
Old 07-06-2008, 10:36 PM
  #27
Davidka - Amain don't have the Picco P7r parts. They got a new Picco P7r 3 standard engine. Even if JPX.21 had parts; only problem I would face is the glow plug.
Old 07-07-2008, 09:36 AM
  #28
ezveedub's Avatar
If the Picco uses standard plugs, it should be like Novarossi plugs I believe, not OS. I think the Picco turbo plugs is like an OS, but I'll have to check later today.
ezveedub is offline
Old 07-07-2008, 09:46 AM
  #29
Trader Rating: 66 (99%+)
I was planning to go with the OFNA Picco .21 P7R EVO3 Off-Road Competition Buggy Engine. I wonder if the engine favors the OS P3 plug.
according to Jay Halsey, he stated NOT to use a OS plugs in the jpx/evo2-3 Picco engines, it will cross thread the original threads allowing dirt to enter the engine....just some food for thought
pwnzor is offline
Old 07-07-2008, 09:51 AM
  #30
Trader Rating: 27 (100%+)
well too bad ive been running the os plugs since i blew the original without any issues the novarossi plug would crossthread but the os plug went in fine
cheesecake is offline
