??????????????need help with a sterring issue??????????????????????
hey guys i have a team losi muggy and ive had it about a year and the sterring on that thing is horrible its sloppyer that a sloppy joe and its so hard to turn it but i had raced it today for the first time and i want you guys to tell me how you fix that because the way its set up you just cant tighten it because then the sterring will bing on it i had also heard there is a way you can put a jato sterring set up in it but if there is anybody out there and that can give me part numbers or even pics or sell me a sterring set up i will gladly appreicate that thanks guys
You could figure out what the tight/sloppy part is by removing the horn from the servo and taking the linkages apart piece by piece. I just did the same thing today on my OFNA buggy, steers like a dream again.
Please use punctuation. I can't make sense of what you're on about. It's spelt "steering" not sterring.
I dont mean to be an asshole but how old are you?
is it your servo thats weak?
maybe something needs to be oiled? or a screw is way too tight? or a bearing(s) in our steering arms are seized?
well im trying to get help and the people are telling me how to type and why dose it matter how old i am i have a jr z9000t servo but the way you have to tighten the linkage it starts to bind but i think im done with this thread because i havent had reall any help ill just make a all alumnium linkage i have a bridgeport and a big lathe so ill just make one
The JR9000T is more than strong enough to turn your truggy, there is obviously a problem somewhere else, first thing I would check would be your servo saver. Disassemble it, clean it, give everything a good once-over, and reassemble. If the problem persist, take all the screws out of the draglink, there will be bushings there, make sure that they are not excessively worn, again clean and reassemble. IF you are still having a problem just keep moving down the line, the steering systems in these cars are not complex, its easy to find the problem, it just takes a lil bit of effort.
thank you now sombody is saying something that makes sense but anyways i know what the problem is its the ackerman and if you tighten the nut that hold it together the system starts to bind im just looking for a way to make one that work without all the slop but i found on a site that you can use a traxxas jato 58mm turnbuckle and get some screws that fit nice and tight and im sure that i can figure out the rest but i just need to get the turnbuckle and then i will go from there
well im just looking for a kit that somebody has made up with all the stuff that i would need. ive heard of somebody using a traxxas jato 58mm turnbuckle. but i would like to get all the part numbers that i need so i can order everything at once. butlike i said i know what the problem is its just the fact that it cant be fixed or else the the steering system will bind
