Inferno MP9 thread
#8328
Being new to the MP9 this season I did a lot of reading and got an idea pretty quick that we need to watch for UJ's popping out and also snapping.
My car has 3L on it and i ran the Malaysian Nationals this weekend. Before the semis I decided I would pre-empt a snapped UJ costing me a place in the main and I checked the UJ's for signs of twisting.
Both rears were twisted noticeably. One more than the other. For sure it would had been a snapped UJ in the semi or main and a bad end to a good weekend. I changed them out and was glad I did when I made the podium.
check out the angle of twisting..... the UJ pins should be in a straight line.
#8330
Does the tki2 WC have a darker anodize chasis than the original tki ?
#8331
Not having much luck with my sale in the f/s. seriously very nice with hardly any time on this tki2. Open to offers.
http://www.rctech.net/forum/10292366-post5.htmlS
#8332
Have yet to break my 777 axles on my 777 and they are 20 gallons old and still a runin AND they are bent the the hooters!
#8333
Nope, I know I will get flamed on this but, the fioroni chassie is the same as the tki2, meaning you will need the sides from the tki2 (with gaskets on the bulkheads and steel inserts for the droop screws) with hard coat anodize that lasts longer than the original tki.
#8336
The unis you guy want to get is IFW404B 93mm. NO PROBLEMS AT ALL from the middle set on the rear bushings to the inner bushing setting. NO BINDING
This is the middle setting on the rear bushings
#8337
Hey Coach whats new about the revised 93mm ? thicker ?
#8339
harder metal and heat treated. If like the older ones was bad. NOT
The size are the same as ifw404 older ones
#8340
Thinking of going Kyosho, so is the driveline ok?
