Inferno MP9 thread
as previously stated there are mounting holes between the radio and receiver box, or.... I just stick it in my receiver box an have had no issues as I run a switch between my radio and receiver box
+1 I have the antenna stuffed in the receiver box along with the transponder on both my cars. Never had any problems.
What about the pipe?
There are better hangers. "Spring Thing" from GMK supply (part#GMKSPRING) is one and Mugen (part# MUGE0903) makes a nice one too. Both have a spring wound into the hanger. You may need to slightly enlarge the hole in the hanger mount. I use those in all my cars now. *side note- a single 4mm screw securing the exhaust hanger mount to the chassis is far superior to two 3mm screws in terms of ease of installation
Last edited by My ST-RR EVO; 04-15-2016 at 01:01 AM. Reason: Part numbers and other error
Has anyone actually done the conversion for the tki4 lower front arms? Can I just put my spare rear shafts upfront and the new arms? Or will. Need the new uppers as well? Sorry for the noob question. I am new to K cars. We have two now with another on the way
just ordered my first nitro buggy, chose the tki3 rtr, and it cant come soon enough! so pumped!
I was not aware of a different outer hinge pin was needed on the new arms. Why is that?
new is captured with a nut...old had the screw to hold in place
Thanks Tobamiester. If I have the 93mm shafts up front. Is it still needed to reverse the pills? Are you still running the 91mm shafts upfront?
Oh yeah forgot to mention that. I have 93mm shafts on mine, per the TKI4. 91mm should be fine also providing you run the Pill inboard (only).
So with the 93s you can run the pills in any configuration. Without getting in the danger zone of the drive pin/ diff cups? With the 91s you must run inboard only correct? I have yet to get mine on the track. But the way I drive this is a worthwhile upgrade LOL. Although my kid has hammered his mp9e tki3 plenty hard quite a few times now. And has yet to break anything. Knock on wood hard! I also got the new air filter setup coming. Then I'm gonna be done with the upgrades. The others upgrades just seem to be small refinements. On a already great chassis that I am far from pushing to its limits. But I do like finishing the race.
Also Toby how are you running your pills with the 93s? And if you have been able to run it. what effect on steering/setup/handling have you noticed if you are running it full width?
