Inferno MP9 thread
Victor, I have experimented with the 16 degree blocks and the wheel weights. The 16 degree blocks are a good tuning aid. I found that they do what more castor in all buggies did. The initial turn in is decreased, more steering on corner exit, smooths out the car in the rough and bumpy sections. I find that I only use them on really high bite tracks where the car is really "twitchy" because of so much steering.
As for the wheel weights I only tried the 10 gram front and rear and to me it just felt like I could carry a little more speed over bump sections on the track. I didnt actually get to see any lap times so I am just going by what I felt. Good luck.
THANKS JPZ
the servo saver that comes pre assembled in the TKi3 kit, do I need to tighten this more, or is it set well from factory?
Jpz67 wheelchair the kyosho info
Since I torqued down my servo saver, just review like 10 pages back, people on here started flaming me when I said to start doing it.. h8rz gawwwwn h8.
Anyhow, you risk your servo. I run Futaba and have not had any issues.
My friend did smash a Savox gear set last weekend.
All I can say is Futaba > Savox.
New ride
Just got it together today.
Hi, does anyone know if there is a New Mp9 on the way? A TKI4 perhaps... Nitro
Thank you in advance for any help
For the servo saver ?s, I lock mine down pretty tight. But I also run KO Propo servos. Robert from KO told me he JB Welds his, so that should tell you something about the reliability of their servos.
http://www.losipartshouse.com/catalog/IFW422.jpg
It says 110MM
Would anyone know if this would work for the TKI3 rear center CVD? Would it be better than the stock?
It says 110MM
It says 110MM
It says 110MM
Also check out the HD captured universals, just as with the regular style HD unis, they're chunky and thicker than the regular parts. The HD unis are IFW432, IFW433, IFW434, IFW435 - for front and rear centre unis and also the 91mm and 93mm HD unis, can't remember exactly which part has which part number but they're all there if you check through them carefully.
Hey guys what will the hub weights do for the car?
Hi guys I'm so glad to be back on here. I just got myself a brand new tki3. My last mp9 was the worlds edition right after Cody king won the worlds.
I got a question to ask you guys ,,,,
What option parts should I get besides the orange rear springs and also I'm thinking about getting the king headz extended motor mount but looking at the chassis I don't see an extra hole to mount the arm of the mount to , do I need to drill a new hole in the chassis or it's not needed or should I just get the one without the extended piece .
Thanks for your help ,,, Brian
Guest
