ws3 iii and jp4 >
ws3 iii and jp4
ws3 iii and jp4
Old 04-21-2008, 09:32 PM
jamminnay's Avatar
Default ws3 iii and jp4
i was wondering if anyone has run a jp4 on there ws7iii? i am running a 2045 right now and was considering a switch... thoughts???
jamminnay is offline
Old 04-21-2008, 09:37 PM
Powerlink's Avatar
Just a question ,what is making you want to change ?,I have had that motor and pipe set before it was great . I used both long and short headers for different tracks ,also great mileage with that combo.
Powerlink is offline
Old 04-21-2008, 09:43 PM
jamminnay's Avatar
i am not a fan of the sound of the 2045.. it seems to never clear out.. if that makes any sense.. it just sounds so muffled that it tricks me into think it is to rich on the top end... for one reason or another i was getting way better fuel mileage with a jp3 on my ws7ii.. so thats why i considered trying the jp4..
Old 04-22-2008, 05:41 AM
tex1's Avatar
Thumbs up
News - The JP-4 will be muffled as well. Effra regs are about noise restriction. They design these pipes for milage and top end breathing.
I love the 2045 pipe. It is quiet though.
Honestly, I don't think you will see much difference.
TEX
tex1 is offline
Old 04-22-2008, 08:11 AM
jamminnay's Avatar
well thanks for the news..lol
Old 04-22-2008, 10:26 AM
zJatoRad's Avatar
Trader Rating: 38 (100%+)
I bought that exactly setup (WS7III/JP4) on December 07, honestly, I did not like it, the WS7 felt like it lacked bottom end, then I switched to a JP1 and it was much better.
zJatoRad is offline
Old 04-22-2008, 11:13 AM
RBMike's Avatar
If your not getting enough bottom end out of the WS7III/2045 combo, you might want the longer header (RB198). Another thing to consider is your clutch set-up. Try the next harder spring from what ever your running now.
RBMike is offline
Old 04-22-2008, 11:18 AM
zJatoRad's Avatar
I was actually referring to the WS7 III with the JP-4 , was running a fioroni clutch then.
zJatoRad is offline
Old 04-22-2008, 12:43 PM
RBMike's Avatar
sorry, I though I was the only guy around with a still running WS7 (original). For that motor I like the RB 2020 the best but the fuel economy is not as good as the 2045.
RBMike is offline
Old 04-22-2008, 01:07 PM
zJatoRad's Avatar
lol, sorry again, I meant the WS7 III, I should have mentioned it
zJatoRad is offline
Old 04-22-2008, 02:12 PM
BSC
BSC's Avatar
Trader Rating: 51 (100%+)
I run the JP4 with the RB long header , this does give you a nice power curve and good fuel economy . It produces a higher power curve to the 2045 but that combination gives good power without being to aggresive If you want good bottom end power run a turbo plug button head and up the nitro and if that doesn't work than go the BB C6 , that motor is really aggresive compared to the S7 and WS7 , you'll have more than enough bottom end then no matter what exhaust or header you run
BSC is offline
Old 04-22-2008, 05:28 PM
jamminnay's Avatar
thanks for the info guys.. i think ill just try the jp3 and see what happens
