Picco P7 Evo 2
Old 09-12-2007, 12:17 PM
  #16
I have used Odonnell and OS plugs in Radical engines with no problems.
windellmc is offline
Old 09-12-2007, 07:25 PM
  #17
ILDRVR's Avatar
I just got a Jammin...who is right on the correct plug fit??? Which plugs are correct????
ILDRVR is offline
Old 09-12-2007, 07:47 PM
  #18
oldsavage's Avatar
Trader Rating: 24 (100%+)
We have been running O'DONNELL T-97 plugs in the Jammin .21 and .28 this year with zero issues. Recommended by Matty Matt at Performance R.C. in IDAHO. Using WERKS 30%, both engines still run very strong.
oldsavage is offline
Old 09-13-2007, 07:22 AM
  #19
PTP Racing's Avatar
I got my engine yesterday but no turbo button. I called OFNA customer service and the kid said it wasnt supposed to come with one. I dont beleive him but what can I do about it? I didnt own any standard plugs so I had to go out and buy some. Then when installing it I realized I had to bend my header to make the pipe sit parallel to my chassis. I hope it runs good for all this trouble.
PTP Racing is offline
Old 09-13-2007, 07:50 AM
  #20
Jerseyboy's Avatar
Tried P6 and P3. IMO The P3 seems to be the best.
Continueing with breaking her in. She's had 4 tanks so far and very tight.
I hope she loosens up so I can rev her to peak rpm.
Jerseyboy is offline
Old 09-13-2007, 09:00 AM
  #21
Maximo's Avatar
Originally Posted by Davidka
It's hard to know what's inside the engines but the P7r is a different engine case than the Jammin JPX.21 so they are not the same.
they are 95% the same motor...a few minor differences only.
Maximo is offline
Old 09-13-2007, 03:14 PM
  #22
TeamCarnage's Avatar
Trader Rating: 31 (100%+)
PTP- Both my P7Rs have standard plugs and are absolute Beasts. I had the original engine with the pressed-in crankpin and it was exchanged for the EVO2 motor after the pin walked out. I was SO happy, I bought another for a back-up. That was appx. 2 years ago. I don't run a lot of Buggy, but it convinced me to get a P9R in my Scale OnRoad and it too, is awesome
No Worries...
TeamCarnage is offline
Old 09-13-2007, 06:51 PM
  #23
ILDRVR's Avatar
Thanks for the plug advice. I just found out from some locals that they also run the O'DONNELL T-97 plugs in their Jammin .21
ILDRVR is offline
Old 09-14-2007, 07:06 AM
  #24
PTP Racing's Avatar
I got in running yesterday for a couple tanks and so far I'm impressed. It fired almost immediately and ran pretty good. The idle was low but once I got that adjusted It was good to go. I leaned the bottom end out to bring the temp up over 200F and its got a nice idle and seems to pull nice and smooth through the entire powerband with temps under 220F. Tomorrow I am going to take it to the track and see what it can do. Its always misleading how fast something is while running it on pavement.
Old 09-14-2007, 07:08 AM
  #25
AZRCaddict's Avatar
Jay Halsey has told me to run hot plugs Picco or OS in all of the Picco motors I've had, JPX.21, P7-R Evo 2, JPX.28
AZRCaddict is offline
Old 09-16-2007, 11:09 AM
  #26
Jerseyboy's Avatar
Ok this is my take on the Jammin JPX21.
I ran the engine on 25% Sidewinder and must say its very easy to tune, it holds a tune forever and just wont flame out.
The engine still has some metal pinch and has loosened up considerably.
I can compare it to a Vspec and a Go21. Maybe you'll get the performance.
The Go makes lovely power very strong and on tap.
The Jammin's power is decieving. Not as snappy as the Vspec. Very smooth strong bottom end. I seem to constantly want to pull wheelies when powering after a landing.Ceceptive power.
I played on the track at race pace and got 10 min 30 sec on a 125ml tank.
I could push it to 11min probably. Engine tune still rich, running 210deg . I wouldnt opt for 10 min pitstops in a race but I should be able to pit comfortably at 7.5min.
The more I drive it the better it seems to perform. I'm using a JP3 and it screams, definitely has a high pitch scream of its own.
Its an excellent egine for winning races as its got everything you need, strong bottom end and midrange and screaming topend.
It idles consistantly, doesnt die for no reason. You dont have to swear at Marshalls because they are slow.
Yes definitely a new edition to my stable.
I prefer them over my Go's and Nova's.
Old 09-16-2007, 06:46 PM
  #27
Hey Jerseyboy I have a question for you. What pipeset are you running. I would assume a Jammin? I would tell you that you may find that snap on the bottom that your looking for with a 069 pipe. A bit different then the Jammin1,2,3. Try it you might like it unless you have. I have never had a issue with the bottom on any of the Picco based engines. Just need to add the right pipe. Also is the Jammin a turbo engine? ID not see if you can change the head button and there will be some more bottom power for you.
xspower is offline
Old 09-17-2007, 03:55 AM
  #28
Jerseyboy's Avatar
I'm using a JP3 and I like the engine as is. Its wicked and I will get another one for me soon.
I'll get me a 069 later to try.
Old 09-17-2007, 04:12 AM
  #29
No problem I think that may help you a bit more with the bottom.
xspower is offline
Old 09-17-2007, 06:16 AM
  #30
aussies1129's Avatar
Trader Rating: 74 (100%+)
Hi everyone I am seriously looking at the picco P7 to go into my kyosho 777 but am also looking at the go tech .21 turbo or os vzb vspec T any suggestions, I have a picco JL .12 red dot in my G4s onroad and you have to use picco plugs, is the P7 the same cause not alot of shops have picco plugs??
thanks!
aussies1129 is offline
