XRAY XB8/XT8 THREAD
#151
I Ran the setup this week with Losi Silver springs on the Blue aluminum shoes and Gold spring on the composite. It suited my driving style perfectly for my local track! The Clutch engaged w/ a linear feel and I could rotate the car with a quick snap of throttle. The Bearings are of there second week now and a I’ll be giving them more of a durability test this weekend. This Clutch is Awesome!
http://www.amainhobbies.com/product_...oducts_id/3665
http://www.amainhobbies.com/product_...oducts_id/4318
Do you think one of these would work?
#153
Nothing is wrong with the stock clutch. It is just not as adjustable as the losi clutch as far as springs and shoe compounds. It also takes longer to change a standard clutch and do maintenance on it. I also like the fact that the bell wears more evenly because there is no gap for the spring. More of the clutch is actually touching the bell and that should mean a more positive hookup when sprung correctly. I plan to run the Dynamite Max Life shoes too instead of the stock Losi shoes.
The other thing is I am using it on a TQ so its a great way to move the engine back a few mm like on the EC without having to buy all the other parts to move it back the way it is done on the EC.
#155
What is the biggest lipo pack that is fitting into this car? I have the one that is about 1250ma but was curious if there was another one out there that was bigger.
#156
I assume your using the Losi engine mounts as well. THe Losi clutch is fantastic, it's easy to work on and does add alot more adjustability than most 3 shoe clutches.
This question is directed towards anyone: at one point there was a list of differences between the TQ and the EC. I've looked around and haven't found much, can anyone provide a link/list of these changes.
THanks, Kevin.
#157
Registered User
#158
So are you using the Losi clutch on your Xray? I haven't tried it yet but I have all the parts coming in on Tuesday. Do I need the Losi mount? The guy who posted previously about this said he was using the Hyper 7 mounts.
#159
http://www.amainhobbies.com/product_...ducts_id/15789
#160
Are there any batteries like that one with a balance lead on the end so you can use a lipo balance charger? I need one with at least 2000mah that fits in the XB8 battery box the normal way.
Or is it hard to add one of those leads to the Protek pack?
#161
This is the one I have been using it is good for about 1 hour of run time.
http://www.all-battery.com/index.asp...ROD&ProdID=986
I was curious if this one would work. It is 2000mah
http://www.all-battery.com/index.asp...ROD&ProdID=972
I haven't measured yet but I think it would.
#162
I wouldn't mess with adding the leads to the Protek pack.
#163
Ok but I would like to know if it is possible to add the balancer. I have the HT balance charger that only has the hookups for the balance leads from the battery.
#164
