RC10GT2 thread!
#31
so tebo uses the ft smoothy muffler, which store carries this product
#34
i hope i can get my hands on one soon!
#35
just finished the winter season with gt2 indoor racing .and i took 1st in the points series at my local track.and it doesnt take a tz to win.even on a high bite track that we use slicks on a clay track.the os .12cvr does just fine.
now to problems ive found on gt2.fuel tanks have issues,the rear camber block is weak replace with alum.,and yes the early kits had screw problems, overall the truck is great/predictable.also by changing the tranny/upperdeck brace between
alum. factory team/rtr plastic brace it does change the way it handles.
good luck to all.
good luck to all.
#36
FYI: I just checked and AE is shipping out another batch of GT2 FT kits this week....
#37
By putting the plastic tranny brace on, what exactly does that do to the handling? My buddy just put the plastic one on and gave me one to try also. Just wondered what the differences were. I haven't got to really run my duece yet.
#38
tends to not make the truck jump nose high as much.
#39
Originally Posted by Ollie 45
By putting the plastic tranny brace on, what exactly does that do to the handling? My buddy just put the plastic one on and gave me one to try also. Just wondered what the differences were. I haven't got to really run my deuce yet.
The plastic flex`s more, producing
more flex in the chassis ...
makes more traction over all...
#40
After only running 3 tanks through my duece, it's been stalling like it is out of fuel with about 1/4 left. Is the tank junk or could it be somthing else. I need to get it fixed by Sunday. After topping off the tank it refires but than stalls with 1/4 tank left. Please help
#41
Please check the fuel pickup in your tank. Is it moved to one side, and maybe the hose pulled off of the filter?
If there is a problem like that, AE had already updated the tank and they'll replace it. The new tanks have 3 pegs in the bottom to keep the pickup from moving around and becoming detached.
#42
i like my gt2 truck and i ran my truck last weekend and it is handling good it
i use 30% odonnell fuel and i run my engine cv-r .12 .
it is only problems is my truck cant triple jump bec truck is nose up and
my tires alike ballon and i did put glue on tires already
i need help
thank tommy
i need help
thank tommy
#43
#44
i want a .12 motor with a 12e carb and has a sg shaft already on it
or get a motor like the os vg .12 12e but the shaft has to be cut
if 1 get the vg-p with the right shaft can i switch out the slide carb with a rotoary carb and where to get the carb
#45
And Ollie, you can just run my extra tank. It'll last a raceday for ya.
