RC10GT2 thread!
#4220
MadCityMotorMan, Plenty of room. I have foam on all sides, top and bottom.
#4222
How are people liking the VTS slippers? I had one on mine last year, but took it off. It seemed too inconsistent. It would not "bite" the same from corner to corner, lap to lap. I did not know if a .12 motor was not enough torque to keep the temps up on it to be consistent (compared to a BL motor).
#4226
Here's mine ready to rock it's almost as nice as yours Ron!
http://www.rctech.net/forum/r-c-item...rtr-truck.html
#4227
What are you selling it for? At least hang on to it till after Omaha.
#4228
Just finished up installing B5 ball studs and HD ball cups. Front tower needed a little shaving to get full movement. Rear inside mount needed shaved of about 2mm for fit and to keep center-line of balls the same. Keep in mind, original tall ball studs are the same measurement from base to center-line of ball. Short ball studs are 1mm shorter. I must say, it is quite a bit heavier duty!
Just wanted to bump this post to anyone looking to put B5 ball studs in.
#4230
Google is our friend. I would start with "1/10 rear exhaust .12" and go from there.
