Losi 8ight building and setup
#3841
You know Glitchy, your absolutly right. The allusive Losi hop-up's......
#3842
Don't get me wrong, I really like the car. However, every time you turn around Horizon is pushing the expected delivery/in stock dates for all the key accessories back a couple weeks or months. They aren't the only ones that do it, but they seem to do it more than most. Waiting for a car design to be perfected is one thing, but waiting for a key upgrade that gives everyone problems and things like filter elements is something else Especially, when some of the delays are keeping peoples cars sitting on shelves.
#3843
Agreed, i just dont know what's taking them so long on the rear bearing insert's.
#3844
Also, my LHS has about 20 Losi 8/8-T air filter elements on the shelf, which i didnt know, and i ended up getting the PSR filters from A-Main myself. Horizon can't control how many Bearing inserts and filters each individual shop will order, especially for those kits that the shops can barely keep in stock...
#3846
Originally Posted by micrors4guy
Drake said it before on the trinity forums. They werent expecting the losi cars to be this "BIG" of a hit.
I want a stock looking split center diff mount. I dont like the q concepts one.
Manny
#3847
The only thing I hate about the Q concepts split center diff is the price. I'm sure losi could whip up a plastic one quite easily.
#3849
Originally Posted by Davidka
You've got that backwards (about piston hole size). The Smaller numbers are bigger holes. If you compare 55/35 wt rear oil with say 56/27.5wt the 56 piston setup will have more high speed compression damping, known as "pack" in RC circles. It will resist bottoming better, the car will ride a little higher in the ruts and it will be more stable. Weight transfer is slower with more pack so it might slow the handling of the car down slightly.
#3852
Originally Posted by W.E.D.Jim
JConcepts TL8 we just finished up tonight.
...Jim
W.E.D.
#3853
Once again great job Jim!!!!
#3854
Hello guys I jus picked up a losi 8 and was putting on some upgrades on it. If this ???? was asked before(sorry). When putting on the GMK servo tray o-rings do you guys put them in all 4 screws that hold the tray or only in the one that holds the battery box??
thanks in advance
thanks in advance
#3855
ari8, I am about to try Casey Peck's shock setup in my 8. It uses 55 piston up front with 32.5wt and 56's in the rear with 27.5. I was pretty happy with the drake setup but I am hoping this will make the car more planted at higher speeds. My car turns beautifully but feels "floaty" at higher speeds. Casey's setup can be found at www.rcsetups.com
