Associated RC8B4.2 and RC8B4.2 Euro
New! RC8B4.2, RC8B4.2 Euro, and RC8B4.2e Team Kits
Tuesday, May 26, 2026
(Pictured: RC8B4.2, RC8B4.2 Euro, RC8B4.2e Team Kits)PUSHING THE BOUNDARIES
1:8 scale off road racing is one of the hobby’s most challenging disciplines; it requires a high standard and demands attention to detail.The latest development to come from Associated Electrics’ Area 51 is designed to push boundaries of performance and build upon the number of accolades accumulated by the RC8 series.
RC8B4.2 Team Kit Features
- New molded height-adjustable gearboxes front and rear
- New offset hubs and updated rear suspension arms to accommodate new hub geometry
- New -4mm chassis in FWB configuration
- New high-volume center differential
- New long chassis brace options
- New high-downforce wing
- Now includes FT hard-anodized aluminum shock bushings
- Updated brake pad material and brake spring
- Soft blend material suspension arms
- 8-degree KPI steering blocks included
- 44/13 ring and pinion gear sets
- 92mm universal driveshafts with 17mm outdrives
- 19mm diameter HTC internal differential gear set
- Optimized setup for tracks with loose dirt and large bumps
RC8B4.2 Team Kit
UPC: 784695809543
Available Pre-order
RC8B4.2 Team Kit Euro Edition Features
- New V2 FWB chassis
- 20mm diameter HTC internal differential gear set
- Optimized setup for high-speed and high-grip tracks
UPC: 784695809567
Available Pre-order
I'm curious about something: I haven't driven a pivot-ball car since the B3, and I notice that very few (if any) drivers use optional light-weight pivot-balls. In fact, I've seen a few add weight to the front uprights. Does the handling improvement outweigh the benefit of shedding a few ounces of unsprung weight?
As for adding weight to the hubs, that will make the car more lazy, effectively slowing corner entry or transition. I could see it as something to try when running on a very smooth surface, but I would rather add weight to the chassis.
Forgive my ignorance, but wouldn't you be able to accomplish the same steering slowing by dialing in some caster with shims or by adjusting the speed of your steering servo as opposed to a change that incurs a weight penalty?
