Tekno NB48 2.0
#346
R/C Tech Elite Member
Trader Rating: 123 (100%+)
I would definitely get the Tekno aluminum arms for steering and throttle/brake. They fit perfectly and you won't need to worry about a failure.
#347
Any chance someone can get me this measurement? Thinking of making a nitro MT410 and am trying to figure out what bodies would fit width wise. Thanks!
#348
Hi. Has anyone had an issue with cooking throttle/brake servos in this car. Just trying to figure out what’s happening. Not new to nitro or RCs. I know about endpoints and I even use a chunk of fuel tubing at the end of the linkage so it’s easier on the servo. Been through 4 servos. First 3 were with a aluminum horn. Put in a plastic horn and I thought I fixed the problem but within a couple of runs it cooked another one. Servo gets hot and just stops working.
#349
Nope. I've never had that happen. Not on my NB48 2.0 or on any other car.
#350
#351
What servo's are you running ?
#352
They are the right size to shim the clutch bell.
#353
figured id post some things it could be, sorry you may know all this already but some stuff to just check over.
#354
I rebuilt my buggy to the Jared Tebo Summer 2020 setup with VRP XV3 pistons and it's like a whole new car. I've never had it drive this well before. I'm also running the new truggy 18 degree carriers and using the outer hole so the front links are a little but longer.
The car has tons of steering, it's easy to drive, and I think the piston help it stabilize quicker coming out of jumps.
#355
#356
I had another great race with the Tebo Summer 2020 setup last Friday. We didn't have enough nitro buggies to form a class, so I ran with the ebuggies and was able to finish 2nd. This setup has completely changed the car and made it both easier to drive and faster. I highly recommend it along with the 5x1.5 VRP pistons.
#357
Techno has a front arm and rear arm that are distinctly different from other brand kits. Let me know how the length of the arm and the angle of the caster affect the drivingability of the techno.
#358
#359
it's right in between 7 7/16' and 7 1/2". Looks to be exactly at 190mm.
#360
Had a great race weekend with my Tekno 2.0s. Managed to hold on to 4th place in the nitro main and got my first plaque. No broken parts on the cars, and the only change I made was adding more rear toe (3.5 degrees) to the buggies to add some on power stability.
