Like Tree346Likes
Mugen MBX8
    Hide Wikipost
Old 05-31-2019, 05:05 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX8
Last edit by: E1 Diablo
E2025 - MBX8 Worlds Edition - April, 2019
MUGE0240: Wide Offset Wheel Hubs 1mm 2pcs; The 1mm wide offset wheel hubs will increase stability and cornering.
MUGE2146: Inline Front Uprights; The E2146 inline front uprights have smoother steering compared to the stock E2147 trailing front uprights and work great in high traction conditions. E2146 uprights can be used with both CVA and universal style driveshafts.
MUGE2168: -3mm Front Upright Arm; The -3mm front upright arm improves the initial steering response and make the vehicle more stable through the middle and exit of the corner.. The new upright arms also reduce bump steer and make the vehicle more predictable in bumpy conditions.
MUGE2235: 46T Spur Gear; The 46 tooth HTD spur gear provides a great balance of acceleration and top-end speed.
MUGE2252: 12T Pinion Gear
MUGE2254: 42T Conical Gear; The optional 12T bevel gear when used with the 42T conical gear will change the final drive ratio and increase acceleration.
MUGE2260: Center Joint Cup.
MUGE2261: Center Front Dog Bone (84.5mm)
MUGE2262: Center Rear Dog Bone (115mm); The front and rear-center dogbones for the MBX8 reduce friction from the stock universal driveshafts. Less friction will give the vehicle a more efficient drivetrain, increase acceleration, and provide more traction. The dog bones are lightweight, durable, and will increase traction.
MUGE2428: Rear Wing Stay +15mm; The +15mm wing mount has more adjustment and will help increase mid corner rotation and be more stable in high speed conditions.
E2021 - MBX8 1/8 Nitro Buggy Kit
Chassis:
The MBX8 chassis features a new design that improves traction and stability in bumpy conditions and on the exit of corners. The steering post are also keyed into the MBX8 chassis for easier maintenance.
Differential & drive train:
High Traction Differentials are included in the MBX8. The Mugen Seiki HTD provides increased acceleration, longer runtime, and more consistent handling. The HTD's also increase stability, traction, and improve handling in bumpy conditions. The HTD has a new larger volume diff cup to increase consistency during long main events. This makes it easier to time rhythm sections, better in bumpy and low grip conditions, helps to increase traction, and increases fuel mileage.
The new gearbox makes allows you to remove and service the differentials without detaching the suspension arm mounts. Easy access to the front and rear differential.
New straight cut 13T bevel gear & 44T conical gear. The new straight cut bevel and conical gears increase acceleration, runtime, and efficiency. A free and efficient drive train will also increase speeds while cornering.
Light weight one-piece wing mount:
The new lightweight one-piece wing mount lower the center of gravity. The position of the wing and wing mount is optimized to improve the performance of vehicle. The height of the wing mount is adjustable. This allows you to control the down force on the rear of the vehicle by simply raising or lowering the mount on the shock tower.
Light weight high down-force wing:
The new IFMAR legal wing is lightweight and provides amazing down force and cornering. The underside of the wing uses a new design to reduced weight and creates additional down-force.
Suspension:
New suspension mounts. The FF/FR/RF/RR are new for the MBX8.
The front and rear lower arms use a new impact resistant material for increased durability. The new arms are box-shaped and include arm stiffeners to reduce flex and increase durability. Adjusting the hardness of the lower suspension arms is now possible. This allows you to fine tune the steering and traction from track to track. CFRP plates will be released as an option part.
Center differential mount & plate:
The center differential mounts use a stiffer material and has a new top plate to reduce chassis flex and increases clutch bell, spur gear, and clutch bearing life. The reduced chassis flex also provides more consistent handling in all conditions. The top plate design also makes it easier to adjust the brakes and easier maintenance.
Enclosed Battery box and updated carbon fiber radio plate:
The MBX8 still uses a flat 2S Lipo or Life battery, but the receiver battery is now enclosed in a molded battery box. The battery box allows for quick and easy access to the battery. The molded box also helps protect the battery from hard impacts. The battery box is mounted to an updated carbon fiber radio plate.
Other new parts and upgrades:
Body, Clamping Servo Saver Nut, F/R Shock Towers, Front bumper, Front center and rear center universal joint.
Mugen Seiki MBX8 Manual
Print Wikipost
Old 04-01-2018, 05:34 AM
  #496
Trader Rating: 34 (100%+)
I have a brand new MBX8 I may sell if anyone is interested it has a lot of extras on it. It’s never been ran
704-273-4715
mp9racer is offline
Old 04-01-2018, 06:57 PM
  #497
For guys that came from other cars, how does the 8 drive compared to them. Also, is this car loose compared to the 7r?
shark2288 is offline
Old 04-02-2018, 04:30 AM
  #498
tom1974's Avatar
The Car is more free than 7r and mbx8 have more traction and steering is similar associated rc8b3
tom1974 is offline
Old 04-02-2018, 12:49 PM
  #499
MBX7R and MBX8
8 more steering ?
8 also loose in rear as 7R ?
ddick is offline
Old 04-02-2018, 02:27 PM
  #500
Yes to both apparently
Chris Reilly is offline
Old 04-03-2018, 05:25 AM
  #501
samuelsonmark71's Avatar
Trader Rating: 22 (100%+)
I recently bought the 42t under-drive the 8 to see if it may help with the rear end as well as a few other things (change diff fluids, etc) and working on the setup
samuelsonmark71 is offline
Old 04-03-2018, 05:55 AM
  #502
am
Remeber that all Mugen cars will need a running in period of at least a gallon before it starts working as i t should. Drivetrain and espesially CVD`s need running in before the car has rear end grip.
8T and AlbertN like this.
am is offline
Old 04-03-2018, 06:50 AM
  #503
THE PHILLY JYNX's Avatar
part # MUGE0159...who makes these in brass? Thanks fellas!
THE PHILLY JYNX is offline
Old 04-03-2018, 07:38 AM
  #504
M2C racing does, here is the link: https://m2cracing.com/product.sc?pro...categoryId=119
Old 04-03-2018, 08:35 AM
  #505
Is the rear end really loose? How much time do you have on your buggy?
Old 04-03-2018, 08:52 AM
  #506
thank you!
Old 04-03-2018, 09:47 AM
  #507
8 tanks on it so far so it isnt 100% broken in, however, I did go off the stock setup and not off of one based around my 7r set up. The 552 just doesnt feel good to me
Old 04-04-2018, 06:20 AM
  #508
battlle won neobuggy with 10-5-2
with no other car than mugen i did that much diffdernce in feeling with swaybars.
try front thicker swaybar AND thicker diffoil.
gt racing is offline
Old 04-04-2018, 06:26 AM
  #509
I also think the car finishing breaking in will have a lot to do with it as well. Gonna put a bunch of time on her at PNB this weekend
Old 04-04-2018, 06:46 AM
  #510
correct, years ago it took me quite some time to realise this.
plus even a fully broken in car can be tricky to drive when drive train is not free enough.
people tend to not pay enough attention to shimming diffs and freeing up drive trains AND then blame it on the car "its lose" "its tail happy" etc...
