Sc10 Alu steering rack
Has anyone tried the FT Aluminum steering rack on there sc10? I've installed one and haven't had a chance to test it yet. Just lookin for some feed back before I burn a few packs testing at the Plex. If its garbage... Save me from lookin like a clown on Saturday.
It's should be better then the old one because there is no servo saver, this should make your car easier to drive and more consistent
Just be sure you have pretty new ball cups and ball studs on your steering links, if not, you'll be popping them off. Also make sure and adjust your steering endpoints(EPA) and if anything back them off a couple % points from full travel, it will help if you are popping off the links. Just my opinion--
Phil
Phil
thank for the input, and yes I also installed J Concept ball cups at the same time. I was a little concerned that maybe some angle may change, like bumpsteer or ackerman.
