NESCAR OFF ROAD 2012
#317
I ordered last night, so it should be here tomorrow. Only thing I didnt get "yet" was tires and foams....since I dont know what works for this track. Anyone got some suggestons for tires and foams???
#318
I am trying some Cityblocks to start with. I would guess Bowties would be another good option. Honestly I am guessing on all of this for tires. As for foams just use whatever comes with the tire. If you want to do some reserch look for tires for a med to loose track with dusty clay and some dirt mixed in.
#319
AKA I-BEAMS in soft compound work well.
#320
Ok...see if someone can answer this one. Needing a starting point.
46t spur gear on a RC8.2 FT with a Tekin RX8 esc with a T8 2650KV motor = what would be a good starting point for a pinion??? Once I know that I can grab +1 / -1 either way. Just need a starting point...Im almost done building it, just need 2 boots that I ripped getting them installed and I need a shock shaft tool..
#321
Darth with that much of a motor I would start down around 13 or maybe a 14 tooth pinion. Try the I-Beams for tires that Radio Rogue mentioned. He is more experianced in 1/8 than most of us. Also we have a new thread for the 2013 season. It has the combined oval and offroad. Here is the link http://www.rctech.net/forum/nebraska...l-offroad.html Tm are you planning on running your 1/8 Losi this year. It sounds like we could have a good turn out.
#322
Scott, maybe once in a while I'll pull the shelf queen down for a run.
#323
what are the motor/ car specs for oval? looking to run a 2wd sct chassis and latemodel body.
#324
Honda Dude, all of the oval rules are on the top of this page. http://www.rctech.net/forum/nebraska...t-oval-17.html We also have a new thread for oval and offroad here http://www.rctech.net/forum/nebraska...l-offroad.html You will get answers for offroad and oval on this new thread.
