Like Tree396Likes
Tekno MT410
Old 03-14-2017 | 08:50 AM
  #616
noobiznessflyin's Avatar
Just got my TBR wheelie bar yesterday and got it installed and tested. This is a must have and also makes the truck look better imo. I wheelied up and down my block last night and had an insanely great time!
noobiznessflyin is offline
Old 03-14-2017 | 09:15 AM
  #617
vettehigh's Avatar
Smile
Still waiting on mine...They should be shipping out anytime now...Calling today because I want the chassis skid plate too
vettehigh is offline
Old 03-14-2017 | 09:34 AM
  #618
I had a sumo racing rear skid plate installed that I took off when I installed the wheelie bar. The wheelie bar bolts right onto the same area and offers the same protection as the skid plate. Same goes for the front bumper.
AudiJedi likes this.
Old 03-14-2017 | 10:16 AM
  #619
vettehigh's Avatar
Just called T-Bone, they are waiting on the wheels for the wheelie bar for my order to be shipped. Hopefully they ship out this week
Old 03-16-2017 | 05:45 AM
  #620
vettehigh's Avatar
Questions??
Is it worth getting...I will be a light basher if that, nothing heavy on my end so I might pass on the items below unless I need to have
*M2C Racing Tekno Rear Shock Tower Brace?
*Carbon Fiber Center Diff Brace?
*TKR5262 CNC Split Cntr Diff Mount?
Old 03-16-2017 | 07:44 AM
  #621
Mopar2Ya's Avatar
I run the TKR5262 on all my Tekno's.
Mopar2Ya is offline
Old 03-16-2017 | 02:41 PM
  #622
neospirit's Avatar
Just got my MT today. Now I have to decide on tires. I am down to 2 choices - Badlands MX or Super Swamper.
neospirit is offline
Old 03-16-2017 | 07:12 PM
  #623
RCWERKZ's Avatar
Oh nice, either one will look and perform great!
RCWERKZ is offline
Old 03-17-2017 | 04:58 AM
  #624
vettehigh's Avatar
Those are huge..spoke with Tekno and they recommended the Shockwaves or regular Badlands
Old 03-17-2017 | 11:53 AM
  #625
neospirit's Avatar
I wanted to go a little big on this truck. The Badlands MX on RCWERKZ's truck looks great. My son likes the Super Swampers. I will probably end up ordering those.
Old 03-17-2017 | 03:26 PM
  #626
Super swapers are nice wheels.
FunnieKid is offline
Old 03-17-2017 | 03:33 PM
  #627
Originally Posted by Maximo
I would like to see a wing on that !
A wing would be off the chain on that.
NitroJunky721 is offline
Old 03-17-2017 | 03:36 PM
  #628
awesome looking truck!
Old 03-18-2017 | 01:54 PM
  #629
1/8 IC Fan's Avatar
3 minutes between posts... trying to get the post count up i see lol.
1/8 IC Fan is offline
Old 03-20-2017 | 07:22 AM
  #630
Originally Posted by Matthew_Armeni
Thicker center oil will mean the truck will have a tendency to wheelie more. The kit says to build the diffs 100k-100k-50k, F-C-R. If you're driving on looser terrain dropping the diffs will improve handling to a point. If you go too low in the diffs the truck will become "grabby" and diff out in turns, it will feel inconsistent. The lowest I would run the front is 10k, center 15k, rear 7k, but that's the lowest. I prefer thicker diff fluids in all of my race cars so I would never run my MT diffs that light, I'd probably stay above 20-20-20 in every situation.
Another thing to consider is the size/weight of the tires. Bigger heavier tires are going to require heavier fluids to feel the same as lighter tires. The bigger tire usually has more traction, more traction means thicker diffs. There's more rotating mass with the bigger tires so when a tire diffs out and they get going they really spool up - thicker fluid helps keep that under control. Another thing is since thicker fluid means less diff action, there's less heat buildup in the diff. You're diffs will last longer between rebuilds with thicker fluids.
Changing diff oil is a fairly quick and easy adjustment (especially the center) so it's worth trying out to see how the car feels.
What would be a MT410 recommend Weight in mid/rear diff when running only 2WD ? I do not race competitively but plan to remove front shaft for a Test with 1580kv ( high C rated 4S ) using Associated Rivals ; Running surface will be combo of grass, dirt, and pavement .
Elmuggoose11 is offline
