NEW Losi TEN-MT
#31
I have had mine for a couple months. I did crack the chassis but it was a 20 parts. Took about 20 minutes to change. Very fun basher. Only issue is motor heat and tires ballooning.
#32
could one of you fine sirs measure the length and width of the body for one of these. i am thinking about trying to make an eb48.3 or eb48sl into a tenth scale monster akin to one of these. thank you the help would be appreciated
#33
5 7/8ths width, 15 7/8ths length. At the center lines
#34
excellent! thank you for the information. i couldn't find it anywhere. i think the body is cool
#35
I do too. I also like the way it looks with the body off. Basically a scaled down copy of my losi eight e..... with more plastic parts.
#36
Pretty sweet rig - might have to dump my Mini 8ight-T for one of these.
#37
Like tha look of it but hate its all plastic...Dropping $400 on it and can't get a aluminum chassis is just wrong IMO ...
#38
Ive seen one of these in person recently, The plastic chassis though looks unappealing in the pictures...It appears to be rock solid...Had alot of fun bashing around with this...really thinking about picking one up
#39
Drop 500 on the scbe and you get the aluminium chassis. Realistically you can get a aluminium chassis for what, 60 bucks. It takes 20 minutes to swap with 2 people.
#40
I'm looking to pick one up, but I'm hearing the runtime on 2/s 5000 is around 8 minutes? Is this true?
#41
Looks like a good truck hmmmmm
#42
What are you doing with it? Just bashing, I can jump/bash for 30 minutes on 5000 2s. Doing 1/2 to full throttle around a sand pit for an entire battery I would say pretty close to 15 minutes.
#43
Has anyone tried to convert the 14mm hex's to 12mm? or maybe even 17mm?
the wheel and tire choice is very limited.
I was going to buy a set of the stock hex's and try to cut them down to 12mm
and drill a larger axle hole in a spare stampede wheel.
unless anyone has a better idea.
#44
They sell conversion kits. Mine is converted to 17mm at the moment.
#45
what wheels/tires did you use?
