Custom MT build advice >
Old 02-02-2016 | 07:47 AM
R/C Tech Elite Member
Default Custom MT build advice
I got a Wheely King over the holidays. Instantly love it. I have learned a lot from tinkering with it and researching online about RC Monster Trucks. So I decided to do a custom build. The main thing I want is a brushless, solid axle rig. So I saw a lot of people use the Axial platform for custom builds. What other transmissions besides the Axial's can I use? I've looked at the WK and Ground Pounder already.
DGordon13 is offline
Old 02-02-2016 | 08:03 AM
Mwildmann's Avatar
How about the chain drive trans from the Kyosho Mad Force Kruiser VE? Definitely something different and appears possible. That's the first idea I had come into my head while reading your post.
Mwildmann is offline
Old 02-02-2016 | 10:15 AM
I personally think the Axial trans is one of the better options. Pretty tough stock, aftermarket to make it tougher, compact and easy to mount on a center skid.
One trans I don't see listed is the Traxxas Emaxx trans. They're a bigger trans so the truck needs to be on the larger side. But they're available as a 2 speed and should prove to be plenty tough for just about whatever you come up with.
Overdriven is offline
Old 02-02-2016 | 10:37 AM
The size is gonna be 1/10 scale. I am using Axial AX10 axles. I wanted to use AR60, but I'm building on a budget. I thought about the EMaxx but it might be too big. The drive chain seems a lil too advance.
HTML code is On
